RV.Net Open Roads Forum: Tow Vehicles: 04 Chevy 2500 tow mirrors
Search only in Tow Vehicles
 > 04 Chevy 2500 tow mirrors
DRM796
Eastern Shore of MD
Posted: 12/02/11 10:39am Link  |  Print  |  Notify Moderator
Just recently purchased a 2004 Chevy 2500HD. Was trying to extend the tow mirrors but only the dirver side extend. Either I am not operating them properly or something is wrong with the passenger side.
To extend them I put the mirror selection switch in the middle position and then press the left arrow on the adjustment switch. At that time only the driver side extends. When I press the right arrow the driver side retarcts. Can someone let me know if there is something else I need to do to get the passenger side to extend or is there something that has malfunctioned? If something has malfunctioned, has anyone seen this and any suggestions on what could be the cause?
Thanks
2012 Wildcat 313RE
2004 Chevy 2500hd crewcab long bed Duramax/Allison
bob213
Fresno, CA
Posted: 12/02/11 11:08am Link  |  Print  |  Notify Moderator
Check out his thread:
PowerVision
APT
SE Michigan
Posted: 12/02/11 11:20am Link  |  Print  |  Notify Moderator
Spend $183 on some Amp towing mirrors on Ebay and throw those away.
2012 VW Passat TDI
DRM796
Eastern Shore of MD
Posted: 12/02/11 12:00pm Link  |  Print  |  Notify Moderator
Thanks for the tips but hoping to fix it myself. I have determined that the motor runs but does not extend. I have removed the mirror from the truck and I was going to try to remove the rubber cover and plug it back in and try to see if I can see were it is failing. Anyone ever had on of these apart? Any suggestions on how to disassemble the mirror?
Thanks
r4wheel
Alabama
Posted: 12/02/11 12:45pm Link  |  Print  |  Notify Moderator
Mine do the same thing. Just be sure to pop the dust cover off and lubricate the drive gear every once in awhile.
2004 Chevy 2500HD CC/SB 4x4 6.0 Gas 4.10
2011 Jayco 32BHDS 1400/14,000 Equalizer
DRM796
Eastern Shore of MD
Posted: 12/02/11 01:41pm Link  |  Print  |  Notify Moderator
Thanks r4wheel. How did you go about doing this. Are the gears behind the mirror or between the mirror and mount plate?
DRM796
Eastern Shore of MD
Posted: 12/02/11 02:03pm Link  |  Print  |  Notify Moderator
APT, it sounds like you do not like the original mirrors, if that so why do you like the aftermarkets better?
Thanks
drm796
jbadtoy
Sin City
Posted: 12/02/11 06:13pm Link  |  Print  |  Notify Moderator
My did the same thing and it was the right side of the truck to,and I just bought the OEM manual extending ones. Because it was only a matter of time that the other one did the same thing,and I would be right back into changing that one out to. I like to know that I can just slide them out anytime I need to,instead of them not working the one day I really need them to move under there own power.
07 Z71 1500 4x4 6.0
08 3500 Dually 4x4 just for work
05 2500 D MAX 4x4 8 inch lift 37 inch toyos tuned,4inch exhaust,intake and more.
26ft Carson Inbox loaded for the toys
28ft Caliber One Boat
18ft Carson Car trailer
Randu
South Central Michigan
Posted: 12/02/11 06:29pm Link  |  Print  |  Notify Moderator
When I get 1 that don't go out, I fold it back and forth and then it works again for the next 6 months. Mirrors are ok but If one died I would replace with something like what is coming on the new trucks. I like a bigger mirror vertical and the smaller convex. Randu
2004 GMC 2500HD 8.1 Big Block gas
2008 Mobile Suites 36TK3
DRM796
Eastern Shore of MD
Posted: 12/02/11 06:52pm Link  |  Print  |  Notify Moderator
The more I look around I think I'm going to replace them. Like Randu, I also like the looks of the vertical with small convex mounted below. Seen them one ebay power, heated, with signals for 229 free shipping.
Thanks for all your help
