Turbo Diesel Dude
Green Mountain, NC
Probably the electric motor driven shifter on your fron axel is bad. Happened to my Dodge. Simple changeout. Maybe $100 ?
charles weidman
WellShooter2
West Texas
I have heard of one repair method that makes it bullet proof. Mudders and off roaders put a stick up thru the floor and shift manually. No more problems.
2008 2500HD D/A
2008 Keystone Challenger
hawkeye-08
Northwest
Might be a bad dash switch, easy to replace and not too expensive. There are rebuild services for the switch also. I took mine out on my 98 Yukon, cleaned it and reinstalled, been working a couple years now since I did that.
Here is a link on the truck forum.. http://www.gm-trucks.com/forums/index.php?showtopic=84347
blt2ski
Kirkland, Wa
Warn or a company called posi-lok or equal, has a wire manual off-on way to by pass the solenoid which does cause issues upon occasion. Gives you the option of a 2lo!
It's NOT the transmission that is the issue as said many times over!
Marty
05 Chev CC D/A LS Dooley
3 Single axle utility trailers
Check RV.Net Blogs at: blog.rv.net
jassrnj
Bath, PA
THANKS FOR ALL THE HELP - I will pull the switch tonight when I get home and check it out first.
Jbird
I had a 2002 D/A with the same problem, but I cant remember whether the switch light blinked at me. My issue was a blown fuse---worth the trouble to check.
36' Travel Supreme Express,Chev 3500 Duramax
jassrnj
Bath, PA
The solution -
The right front was not locking up when put into 4X4. The wire had rub bare on the frame and caused a short. The motor on the transfer case burnt up. So, repaired the wire, replaced the motor and everything is working again.
#40Fan
Colorado
I have replaced more of the dash switches than I can count. I think you are on the right track, Jassrnj.
2013 Arctic Fox 22GQ
2011 Ram 2500 CC LB CTD G56 3.42 Mineral Gray
fiddleman-1955
MO
Allison trannys are bullet proof. Must be an issue with the NVG (Chrysler) transfer case.
coolbreeze01
Redding, Ca
Bullet proof?? I like humor, thanks
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis 8008 Tires.........
