RV.Net Open Roads Forum: Technology Corner: wi fi range extenders
 > wi fi range extenders
Jagtech
Sunny Southern Alberta, Canada
Posted: 12/06/11 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
I bought a G-Sky 500 mw. USB wifi booster on Ebay, at the recommendation of others on this forum, for $37.00. I absolutely love it! In places where I get 1-2 bars from a single access point, the booster has given me as many as 18 access points, some with 4-5 bars strength.
1998 Triple E F53 with 460 Ford
1995 Jeep Wrangler toad
Golden_HVAC
Fulltime, CA, USA
Posted: 12/06/11 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
I use a Hawkins antenna that plugs into my USB port, and once when camping at Morrow bay I used a pair of 6' extension cords to put the antenna on the roof of my motorhome, tied down with wire ties, and inside a 1 gallon plastic baggy!
Being on the roof, and attached to the mostly plastic refrigerator vent cover, it gets much better line of site to the clubhouse, or more likely the tree next to the computer that runs the Wi-Fi system.
Hawkins HWL2 antenna.
Fred.
michael7000
Grant FL.
Posted: 12/07/11 06:42am Link  |  Quote  |  Print  |  Notify Moderator
WOW. Thanks for all the responses. I will start to look at some.
Monty-Rob
Sioux Falls, SD
Posted: 12/07/11 08:27am Link  |  Quote  |  Print  |  Notify Moderator
I have the PepWave Surf Mini. Many times at campgrounds where I could not pull in the wifi signal the Pepwave saved the day with a strong signal......purchased this through 3GStore.
2012 Started fulltiming on February 1st
2009 Carri-Lite 36XTRM5
2008 Ford F-450 Lariat
Ivylog
Blairsville, Ga. USA
Posted: 12/07/11 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
If you already have a external WiFi adapter with a stub antenna, you can replace that poor antenna with a Yagi antenna for less than $10. The biggest bang for the buck is in the antenna. Nothing beats a Yagi antenna for increasing signal strength. Having bought dozens of these for $37 for people in my RV park, it is a cheap solution to increase the usable distance from the WiFi source.
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
fcooper
Richmond Hill, Georgia
Posted: 12/11/11 08:47am Link  |  Quote  |  Print  |  Notify Moderator
Does this connect via wire to a laptop usb port or does it connect to the laptop via wireless?
Does it support multiple devices, or would you have to connect it to a router for multiple devices?
Thanks
Fred
Fred & Vicki
Richmond Hill, Ga
2000 Holiday Rambler Endeavor/Freightliner/330 Cat
2000 Honda Odyssey toad w SMI Silent Partner braking system
Tire Sentry monitoring system
Jagtech
Posted: 12/11/11 10:26am Link  |  Quote  |  Print  |  Notify Moderator
It connects directly via the USB port. Its here:
Wifi booster $37.00
CopanoCruisin
The Great State of Texas
Posted: 12/11/11 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
Being a bit electronicaly challenged, we are getting an Ipad2 and I really do not understand all of this information. How will I have to connect the booster to the Ipad2? Ivylog, Jagtech or others please reply and talk very slow. Thanks !
BeachinBeemer
Wilmington, NC
Posted: 12/11/11 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
I need to be able to connect android tablets(Toshiba) or MacBook Pro's to the system I have an apple wireless router....would I connect the booster to the router and then log in through the router network?...Thanks...I'm tech challenged and my son is too far away to help..George
MrWizard
Traveling
Posted: 12/11/11 11:32pm Link  |  Quote  |  Print  |  Notify Moderator
the extenders being discussed connect to the PC via USB port
the easiest way to use an Android tablet will be to use a WiFi "repeater"
but all the ones i have seen, need a PC to set them up
my Hawking repeater, required me to connect the PC via LAN cable to setup the repeat function ( connect to the correct wifi signal ) and repeat it
after setup any wifi enabled device can access the "hawking" repeater
IF and when i change locations and want to connect/repeat an external wifi hotspot (access point) I have to do the setup again
its NOT an automatic "plug & play" process
if your going to be in ONE spot for a while, its NICE to have, but you have to connect it to a computer to access the "repeater" setup functions
once its setup just leave it turned on 24/7
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
