RV.Net Open Roads Forum: Camp Cooks and Connoisseurs: pressure cooking eggs
Search only in Camp Cooks and Connoisseurs
Open Roads Forum  >  Camp Cooks and Connoisseurs
 > pressure cooking eggs
swtgran
Brimfield, Ohio
Posted: 12/06/11 05:42pm Link  |  Print  |  Notify Moderator
For those of you with pressure cookers that have PSI settings of less than 10, preferrably closer to 5, you can cook fresh eggs to hard cooked in 6 min. and have fresh eggs peel very easily. They need to be up on a rack and separated from one another. Add 1 cup water to cooker and cool naturally. If you want soft cooked, cook 3 min. and cool immediately. Medium cooked, 5 min., cool immediately.
I think electric cookers need to use the veggie setting.
Swtgran
2007 Casita 17ft SD
2005 Toyota Tundra
John&Joey
Some Location
Posted: 12/06/11 11:28pm Link  |  Print  |  Notify Moderator
We always used a pressure cooker for the eggs in our restaruant. Cook up 5-6 dozen at a time for use in salads on the buffet.
If you get your timing down right, you will not have a dark circle around the yoke, plus the shell will slide right off with no fuss.
JDelauter
Leesburg, FL, USA
Posted: 12/07/11 05:26am Link  |  Print  |  Notify Moderator
My DW uses a rice steamer. Says it doesn't matter how long (20 mins, etc). I do know the shells come off clean as a whistle
Retired SMCM(MDV) USN 30 years
3 'Nam Tours
As of 11/04 Full-Timing with:
2003 Gulfstream Friendship, Quad slide
1 lovely wife
and 1 sassy Bichon
JDelauter@aol.com
grinder
Courtenay, British Columbia
Posted: 12/07/11 06:43pm Link  |  Print  |  Notify Moderator
Why would anybody want to use a pressure cooker to do boiled eggs ??? Bring water & a tad bit of vinegar to boil drop in eggs and 3.5 minutes they are ready to eat, 8 minutes and they are ready to dip in cold water and put away in fridge hard boiled. It would take longer to bring the pressure cooker up to pressure. JMHO
swtgran
Brimfield, Ohio
Posted: 12/08/11 08:37am Link  |  Print  |  Notify Moderator
The only reason I see to pressure cook eggs is to make them extremely easy to peel. If you have older eggs on hand, they usually peel just fine, but if you just got them from under the hens, they aren't going to peel with the regular methods of cooking. The goal of pressure cooking is to make them easy to peel.
