RV.Net Open Roads Forum: Tech Issues: Connect solar charge controller to converter output?
 > Connect solar charge controller to converter output?
AndyfromTucson
Tucson Arizona
Posted: 12/10/11 12:49pm Link  |  Print  |  Notify Moderator
My converter is in a space right under my refrigerator. I was thinking the easiest way to install my new solar panel would be to run the wires down through the refrigerator vent, install the solar charge controller next to the converter, and then wire the output of the solar charge controller to the output terminals of the converter (instead of running separate wires all the way from the charge controller to the battery). I figure the wiring from the converter to the batteries is already sized to handle the amps. Does this seem feasible?
2oldman
Palm Springs
Posted: 12/10/11 12:55pm Link  |  Print  |  Notify Moderator
That's fine, as long as the converter isn't on at the same time.
RLS7201
Posted: 12/10/11 01:46pm Link  |  Print  |  Notify Moderator
Did exactly what you purpose. I used a Rouge charge controller that plays well with other electrical sources. Both charge controller & converter are on line at the same time with no problem. Not all solar charge controllers play well with others, so ask that question when purchasing.
Richard
BFL13
Victoria, BC
Posted: 12/10/11 01:51pm Link  |  Print  |  Notify Moderator
It is sometimes better to have the controller close to the batteries so the controller gets a better idea of battery voltage for deciding on when to adjust its charging.
If your controller is a simple PWM type like mine, there is nothing to see except a red light, so nothing is lost by having it out of sight up by the batteries. You can monitor the voltage inside the rig with a voltmeter when you get the urge.
In that case, you can run the wires from the panel down the vent and onto the ends of the battery wires at the Dc fuse panel lugs by the converter, and put the controller at the other end of those wires right by the batteries.
Part (most?) of the converter to battery neg path is via the frame, so where you put the controller will determine which side of the controller's wiring will have the frame in its neg path. Not sure it matters--"depends" I suppose.
The controller pos wire should have a fuse on its battery post end, but if you run the controller pos wire to one of the other fuses like for the converter or jacks or slide, it can share that one.
* This post was edited 12/10/11 01:58pm by BFL13 *
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
12thgenusa
Loveland, Colorado
Posted: 12/10/11 03:31pm Link  |  Print  |  Notify Moderator
Wouldn't you always want the fuse to be as close to the output of the controller as possible?
2007 Tundra DC 4X4 5.7, Alcan custom rear springs, 2009 Cougar 245RKS, 370 watts ET solar,
Rogue MPT-3024, 440 AH GC2 bank, ProWatt 2000,100% LED lighting
pianotuna
Regina, SK, Canada
Posted: 12/10/11 04:18pm Link  |  Print  |  Notify Moderator
Hi,
No, the fuse should be at the battery end. The panels and controller produce far fewer watts than a battery shorting out. The fuse is to protect the wire.
Regards, Don
Full Time in a 28 foot Class C, 256 watts solar, 556 amp hours of AGM in two battery banks 12 volt batteries, 3000 watt Magnum hybrid inverter, Sola Basic Autoformer, Microair Easy Start.
12thgenusa
Loveland, Colorado
Posted: 12/11/11 07:26am Link  |  Print  |  Notify Moderator
So if there is a catastrophic fuse right at the battery and the battery output goes to a terminal buss to which the controller is also connected, is there even a need for an additional fuse on the controller wire?
BFL13
Victoria, BC
Posted: 12/11/11 07:43am Link  |  Print  |  Notify Moderator
That is what I meant by sharing the fuse. Can't say it is the proper thing to do because of all the different size fuses available to share with. The solar amps is low but some fuse amps that you might share with are larger than the solar "needs," but I do it anyway.
I figure if the battery is going to be the culprit the amps will be huge so it doesn't matter if the fuse protecting the solar wire is "too big" but I am no electrician. [emoticon]
Be interested in getting the forum experts' comments on that.
pianotuna
Regina, SK, Canada
Posted: 12/11/11 08:19am Link  |  Print  |  Notify Moderator
Hi 12thgenusa,
The catastrophic failure fuse should be rated at what the wire it is protecting can safely carry. If you choose to wire in at the converter the wire from the controller to the converter needs to be the same size as that which goes from the converter to the battery bank. I would not personally do it that way.
On my balanced battery system the catastrophic failure fuse is at the buss and was wired that way by a licensed wind and solar knowledgeable electrician.
The "house" feeds on my RV are protected by two automatic circuit breakers. One in the main battery bank area, and an additional circuit breaker near the converter.
BFL13
Victoria, BC
Posted: 12/11/11 10:11am Link  |  Print  |  Notify Moderator
This is a really good explanation and has examples for the buss situation too. Looks like I might need to re-visit my set-up, not sure if it is ok now.
http://www.bcae1.com/fuses.htm
