Lar's
Traverse City, MI
Just pulled the old TV out of the front compartment in prep for flat screen update... what a job this turned out to be for me anyway. I have a new respect for those that have managed this task and made it sound easy. Finding steel and enough strength to make me feel comfortable took a bit of geometry and construction. I'm sure I overbuilt the structure. Now I have a question for those that have done this "how to you support and hold the swing out TV while going down the road"?
I've searched and found methods for holding along a wall, but this new set is partially inside the existing front opening. Would straps and foam backing suffice or is there a better method?
Thanx for any help.
Lar
Lar
Kayaks/Bikes/Hiking Shoes
04 Country Coach
ISL 370
Honda Fit-Auto
Macktee
Canada
I used the type of mount that you hang the top of the TV mount on the rib, and then the bottom latches and locks. It does not swing out and amazingly doesn't rattle. Very pleased with it. Changing out the TVs, for 2 Led units was the first thing I did after the RV purchase. Macktee
04 Monaco Dynasty Diamond 1V ( Homer II)
2012 Ram 1500 4X4 Quad Cab towed
2011 Dodge Journey
2013 Cargo Mate 24ft enclosed car hauler
Tom and DW Nancy
Holliday Trails member
Good Sam Life time member
FMCA member# F419937
crazyhorse
peoria,az.
ok if your gonna talk about diy you need pic on this forum so we can learn , just saying. thanks
liveneasy
U.S./Mexico
X2 on the photo's. It's difficult to offer suggestions when we can't see what you have done.
Greg
'96 Holiday Rambler Endeavor DP/'03 4wd tracker
Datastorm F1/D2/7000/on SatMx5
See where I am today
Macktee
Canada
liveneasy wrote: X2 on the photo's. It's difficult to offer suggestions when we can't see what you have done.
Sorry I will have to post my pics next spring when I am in closer proximity to my MH (Homer) Macktee
Mick1152
Here
On my first RV, the old TV area left a lip which hung out enough for the bottom edge of the TV to rest on when stored. I glued a thin rubber strip to it to prevent rattles. Then the swing out structure was all mounted inside the old TV area. I used two short bungee cords inside the compartment attached to the bracket on the back of the TV to hold the TV back against the opening. The sides of the opening was lined with a soft foam I covered in vinyl to prevent rattles. Was always secure and never rattled. Just pulled the TV out slightly to release the bungee cords to swing the TV out.
It worked but after a while I found myself never using the swing out of the TV and just leaving it in place. So for my current RV I just used I board over the old TV opening, hinged at the bottom and held in place by a latch on either side of the board. Then just flat mounted the TV to the board. Can see the TV fine without the swing out arm and I can fold the TV down to access the new storage area behind the TV.
Mick
1998 Fleetwood Bounder 36S Ford Chassis
1999 Chevy Malibu LS Toad
~The difference between Ordeal and Adventure is Attitude~
Get Dropbox!
RoyB
King George, VA
The new LCD Flat screen sure make it a lot easier since they dont weight anything... I got rid of all the big heavy analog TVs. All went to the local dump...
I've had pretty good luck with puting up a 1/2-inch large board and use the spring toggle bolts to hold them up to a outside wall. Then just use the LCD TV mounting hardware all the TV stores have (Lowes/Walmart). the large board up first spreads out all the weight of the HDTVs.
One guy on here installed one in a boxed in shadow type box on the living room side and extended the box into the bathroom side and then walled in the part that stuck out inside the bathroom. Looked like it belonged there. The bathroom side only had a full mirror on it anyway so all of that just got moved in a couple more inches...
You can find all things you need for the cabinets and walls from Lowes.
The big thing to do is get rid of the old heavy power hungary analog type TV sets... The new LCD HDTV Flatscreen HDTVs like the 22-inch VIZIO works great picking up the new digitial full screen mode High Def local Natl Digital HDTV signals (which are free) using the OTA BATWING crank-up antennas. This is for the CBS-NBC-ABC-FOX-PBS local broadcast tv stations. We get 6-36 station just about anywhere we go here on the eastern side of the US. They spread out more on western side I think.
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
Kiwi_too
Western, WA
Our cabinet was about 1/2 in too small for the 32" flat screen we wanted, so rather than altering cabinets, we opted to mount a hinged piece of 3/4 plywood, with black vinyl upholstery, as a door, to which we surface mounted the TV.
Before
After
Stereo/Storage behind
May God bless your travels
Me, The Wonderful Wife
and two Spastic Border Collies
U.S. Army Retired
2004 Coachmen Aurora, 3480DS
2007 Saturn Outlook, FROG
Lar's
Traverse City, MI
All GREAT ideas, thanx. Our TV is not centered and my DW wanted it so I could more align it in her direction on the couch, thus the swing out. Liked the bunge cord behind idea, might look in to that. Looks like others have done a great job. I'll see if I can get a pic of my "sturdy" mount. I tried to leave room for storage that I'll build in later (famous last words)
