RV.Net Open Roads Forum: Why new Gas Class A no inverters?
 > Why new Gas Class A no inverters?
jrlibbie09
Colleyville
Posted: 12/11/11 04:44pm Link  |  Print  |  Notify Moderator
Trading in our Class C with 400watt inverter for nice 2012 Gas Class A. Does anyone know why they do not have inverters? I read up on the new chassis with its upgraded alternator to help run motorhome systems. Does this replace the inverter? It is on the F22 Chassis. Thanks
Coachmen Encounter 37FW 2012
wolfe10
Posted: 12/11/11 04:55pm Link  |  Print  |  Notify Moderator
No, an alternator, no matter how powerful (high amp) can not take the place of an inverter.
An alternator produces only 12 VDC.
An inverter takes that battery voltage (12 VDC) and "inverts" it to 120 VAC.
And, sorry, have no idea what an F22 chassis is. F22 fighter plane-- yes.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
OnaQuest
Old enough to be a
Posted: 12/11/11 04:56pm Link  |  Print  |  Notify Moderator
The alternator can't possibly replace or substitute for an inverter. Totally different function.
Different manufacturers find different ways to cut costs. A small inverter is not an expensive or difficult item to install.
enblethen
Moses Lake, WA
Posted: 12/11/11 04:59pm Link  |  Print  |  Notify Moderator
Many rigs have an inverter as an option. Buying off the lot, rigs may not have one just to keep price down and then install as an add on for big bucks.
A good genset and smaller inverters are a good way of going.
What make and model of rig are you looking at?
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
jrlibbie09
Colleyville
Posted: 12/11/11 05:01pm Link  |  Print  |  Notify Moderator
I may have the chassis info incorrect, I know it is the V 10 with 22k lb chassis. Guess I need to look into the inverter option. Thanks. Ill look up what others have done on installing one.
hershey
Albuquerque,(fulltime) NM, USA
Posted: 12/11/11 05:04pm Link  |  Print  |  Notify Moderator
Perhaps your thinking of a converter? That would convert 120 volts back to 12 volts for shorepower power to your lights and other 12 volt items. Having said that, I have to believe that all RVs have a converter of some size to facilitate the charging of their batteries and providing 12 volt power.
The inverter will take 12 volts from your battery and provide 120 volt to the various items in your RV. Size is determined by the amperage load of the devices you want to power. A 400 watt inverter would be adequate for most TV and satellite systems and perhaps a laptop or printer. To power the larger items, like a microwave, vacuum cleaner, you would need a much larger inverter.
And yes, a lot of motorhomes do not automatically have an inverter but one can be added at a very reasonable cost.
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99
rr2254545
Minnesota/New Mexico
Posted: 12/11/11 06:20pm Link  |  Print  |  Notify Moderator
I thought all newer MH had inverters.
2012 Winnebago Journey 36M Cummins 360
131 Campgrounds since we retired in July 2009
jrlibbie09
Colleyville
Posted: 12/11/11 06:32pm Link  |  Print  |  Notify Moderator
It has converter. 2012 Coachmen Encounter 37FW. We do a lot of college football tailgating, and kids may watch tv going down road. Dont like to run generator just for tvs. Thanks
wolfe10
Posted: 12/11/11 06:41pm Link  |  Print  |  Notify Moderator
That would likely be the Ford F53 with 22,000 GVWR.
And Ford would not have fit the converter, charger or inverter/charger. That decision would be up to your coach maker.
Ford only chose the alternator-- 130 amp to 175 depending on year.
riggarob
Farmington, NH
Posted: 12/11/11 07:06pm Link  |  Print  |  Notify Moderator
Having owned 2 gas rigs ('93, '07)niether had an inverter. I installed my own on each. A necessity when dry camping. You can only run the gen set so long w/o going crazy, along w/your neighbors !! Robbie
08 FW Providence 40X
FL-XCS chassis
46"LED,Blu-ray 5.1
Ready Brute tow bar/braking/break away system & wireless light bar
'11 Ford Edge AWD toad
2 Honda 2000s for 30 amp dry camp
&300 watts of solar
Beware of those who point their finger the LOUDEST !
