GULFMAN
MOORESVILLE, NC,USA
Had a coworker stop by and ask if i use a fuel additive in my Powerstroke 7.3 diesel he has 2010 F450 with ?? diesel engine.
Never give it any mind. Do any of you fellows use a additive.
Farmerjon
Niangua, missouri
No I don't , I don't think it is cost effective for improving mileage and I don't know if I need it to keep engine clean or ??? But i haven't done any real homework on fuel additives for diesels so I know very little about them.
00 F350 SC LB 4x4 DRW 7.3 PSD 6sp 3.73 DYI over load bumpers
99 Starcraft 953
87 F250 460 4x4 4sp 4.11 ex cab 8ft
95 jeep YJ 4cyl 5sp
69 f250 360 4sp
Old-Biscuit
Across the USA
Don't know about Ford.......but my Owners Manual for my RAM states not required.
Check your manual for Ford recommendation.
I think it is a personal choice really. Some people use them, some don't. I fall in the Don't Category.......MFG. doesn't require (not that they don't recommend it) just state it's not required.
msiminoff
Silicon Valley, CA
GULFMAN wrote: Do any of you fellows use a additive.
I add Power Service Diesel Kleen at every fill-up. It raises cetane and helps to keep the fuel system lubricated & clean. With diesel over $4/gal, simple math proves that the Diesel Kleen more than pays for itself in increased fuel efficiency.
I also use TCW-3 oil in my '05 Ram, but but I would NOT use it in an engine that was designed to be run on ULSD (like your friend's 2010 F450)
'04 Alpenlite Saratoga 935, 326W of solar, 300Ah Odyssey batt's, Trimetric, Prosine 2.0
05 Ram3500, Cummins, Goerend Trans, Vision 19.5 w/XDE's, Dynatrac Hubs, RR airbags w/ping tanks, Superhitch, Roadmaster Swaybar, Thuren trackbar, RS9000XL/MyRide
BeatCJ
Amboy, WA
We use Diesel Kleen in our tank at work. We had some problems with turbo and EGR sooting on our '04 F-550's. We discussed it with Ford, and one of our issues was that they recommend a minimum cetane level of 41. ULSD is delivered with a minimum cetane level of 39. Since we have been adding Diesel Kleen on every bulk delivery, we have not had to have a repair. We did do some other things too, so it's not just that.
Gordon
1987 F-350 XLT Lariat SRW 6.9
1986 Western Wilderness Alpine Dinette 11
ticki2
NH
Why would you NOT use TCW-3 in a newer diesel ? USLD is lacking lubrication from everything I have read .
'68 Avion C-11
'02 GMC DRW D/A
bedrocker
lompoc ca
I use stanadyne performance formula 7oz every other
tank my brother who is a diesel mechanic tells me
it keeps the injectors happy also it is what Ford
recommends I have a 2000 F250 7.3 and it never gives
me any trouble
T-10 Parabolic
Western North Carolina
I used Standyne in my 86 6.9 Ford diesel, used Stanadyne in three of my 7.3 and also in my one 6.0,( which by the way was one excellent truck) and am now using it in my new 6.7.. It addes lubricicty and also cetane to your fuel system. Some may say it is snake oil but I will continue to use it at every fill up!!!!! T-10
2011 King Ranch, 350 DRW. CC, 8' bed, 4X4 6.7 PSD
2011 34RLTS Jayco Pinnacle
dokkema1
Blanding UT
In the new diesels it helps ...not so many regens...he should use it in a 6.4 with regen..ford sells it
Skipper Rod
Bellevue Nebraska
I use power servie also. especially in winter to keep the fuel from gelling. Had that happen to me once, no more
