I'm looking for input as to HIGH MILEAGE class 'C' motorhomes. NOT/DON"T wand to hear about low mileage units (like mine).
Would like to know year, model of chassis (E350 or E450), length of coach, and what has been done to the driveline and chassis, to keep it running. Hopefully also the mileage at time of those major repairs.
I'm trying to get a handle as to 'expected' life of the major stuff.
How many of us have a rig with over 100K?
If your's has less than 100k, it's not of interest to me, UNLESS it's had Major repairs. i.e. a front end rebuild, or a differential rebuild.
Also V-10s only please. I'm trying to get a handle on the 'New Generation' of power trains.
Hoppe
2011 Dodge 1500 C'boy Caddy
2000 Jayco C 28' Ford chassis w V-10 E450
Doghouse 36' or so Trophy Classic TT
rehoppe wrote: I'm looking for input as to HIGH MILEAGE class 'C' motorhomes. NOT/DON"T wand to hear about low mileage units (like mine)...
Another way of asking the same question might be who can beat the number of miles of this one and then provide a history of work done. Tried to do a search on the internet and found it difficult to locate high mileage ones as the normal search is for low mileage. Here are a few for just an idea.
I bought one in 2000(new). Put 120,000 on it. Changed the oil(3,000mi). E450. Ran like a charm. Used it like a jeep. The chassis was great the box okay. It had some leaks when it was new, so that doesn't count. Stripes faded after a few years. It was outside in Florida when I wasn't on the road with it. Used it 4 months a year. sold it in '06. It was a Thor/Chateau. Bought a Safari Sahara DP. Like it too. Have a fondness for that "C" though. That's all I have........
2000 F-350 V-10 SRW Super Cab, 4x4 Short Bed. Prodigy Brake Control, BilSteins, and Scan Gauge II! 2003 Jayco Designer 31RLS (33ft)
I'm not a judge, it's just a nickname! "SEMPER FI"Vietnam 1968!Don't act stupid- We have congress for that!
2000 V-10 in a 35' Class A: Usually travel at 25,000 CGVW
Installed full BANKS at 1500 miles
Installed synthetic oil and dual filters (normal plus bypass) at 7,000
Installed synthetic in tranny at 15k miles
Had to replace 5 coils at 45k miles
Oil samples tested at 7500 mile intervals & filter changed; Oil usually went 45k miles before changed advised.
Spit a plug at 126k miles; had stainless inserts installed in all cylinders, valves ground, water pump replaced (major teardown is usually required for spit plug). No visible wear on cams.
Engine should be good for at least 250k miles.
Manifold bolt failures are pretty common with standard manifolds. Have only had one on the BANKS headers - at 115k miles.
V-10 engine will be last thing to go on an RV!
Wes
"A beach house isn't just real estate. It's a state of mind." Pole Sitter in Douglas Adams MOSTLY HARMLESS
Mine's not a C, but combines weight is usually 22,000 combined, up to 25,000 and with just as much wind drag.
I change oil about every 10,000 miles, and do a trans service every 100,000 (I'm past due now). I change plugs every 65,000 because the Predator tuner makes them wear faster.
It needs a new starter relay and front o2 sensors every 150,000.
Radiator burst at 265,000 miles. I continued to tow 300 miles home.
Got a camshaft sensor code at 310,000. Replace it with a Napa sensor. New senor threw a code a week later. Put old sensor in after cleaning it, and it's been fine since then.
My differential carrier split in half last month around 315,000 miles. I'm already running the E450 carrier. Drove home about 250 miles this time. Don't know why it busted, but I will admit I don't use the rig gently. This was by far the most expensive repair I've done.
I had a new Ford tracloc carrier put in. If it breaks again, I guess I'll have to go to a bigger axle.
Bryan
2000 Ford E350 DRW Wagon (14-pass all captains chairs)
V10 w/ Banks PowerPack, Diablo Predator, 4.56 LS, ~350,000 miles
New Desert Fox in the works!
I think this supports 1/4 million miles out of most any gas truck engine before the oil plan or valve covers will be required to be removed with 2x of that amount being recorded all of the time. Few Class C MH's are going to be driven to EVER 'wear out' the engine but lack of use and service are the MH owner's main concern.
So in a functional sense mileage of a MH is NON issue.
A worn out engine can last a long time. 50 years ago while the life in miles were lower for many reasons as long as they had enough compression to start and run they were still used.
Have seen a few that would roll when parked in first gear on level ground if the wind was blowing hard.
Now if the roof would never wear out like the engines will not wear out MH ownership would be more simple.
