RV.Net Open Roads Forum: Toy Haulers: Those with Fuzion's power ramp door...
Search only in Toy Haulers
 > Those with Fuzion's power ramp door...
MadMav
Colorado Springs, CO
Posted: 12/19/11 07:08am Link  |  Print  |  Notify Moderator
No recall, just me being overly concerned. Mine will be covered under warranty.
Mav
"A fifth wheel trailer is a bi-level towable mobile home."
Mmaxed
Montana
Posted: 12/19/11 11:24am Link  |  Print  |  Notify Moderator
Our '09 320TE came with the power ramp door. We took the power lift off for 2 reasons. The mechanism took up too much space in the garage and it was too slow. I could drink one beer and have to get another by the time the door opened or closed. I don't remember how may springs ours has, but it does have the zerks on the hinges.
MadMav
Posted: 12/19/11 11:42am Link  |  Print  |  Notify Moderator
I have heard of quite a few taking theirs off because of space. But with me using all 14' of my garage for 4 large toys at times, I have never had it get in the way yet. And mine is actually pretty fast. It can lower the door in about 25 sec and raise it up in about 30 sec.
Mav
MadMav
Posted: 01/05/12 09:39am Link  |  Print  |  Notify Moderator
Update......
The spring setup did not solve the flex issue. We are now working with Keystone in hopes to find a fix that does not require drilling more holes in the door to move the actuator arm up or drill more holes in the floor of the garage to move the actuator to the other side of the garage where there appears to be more support on the door for such torque. We'll see, may end up being a moot point.
Mav
stsmark
Northern CA
Posted: 01/05/12 10:42am Link  |  Print  |  Notify Moderator
Thanks Mav,
Removing the actuator is not an option for me but the flex bugged me knowing what the structure under it looks like. I have visions of all the plywood blocking just floating around loose. Please keep us in the loop.
Mark
Mark, Cathy and Zoey (aka The Golden Missle)
2011 F350 CCSB 6.7 (aka Frosty)
2011 Cyclone 2812 (aka The Little Guy)
Lasher Sport ATH
Lasher Sport BTX
jetboater454
Camping or home
Posted: 01/05/12 11:33am Link  |  Print  |  Notify Moderator
In the video it looks like the hinge is flexing.On my EnduraMax I have a bar all the way through all the hinges.Also have the grease fittings.I also have 7 hinges and 6 springs.
"If momma not happy ....Who cares.I have my TH AND my toys .
2007 Gulfstream Endura Max 40
2001 Polaris Ranger 4X4
Mod Pics
hallogram-az
Arizona
Posted: 01/07/12 06:16pm Link  |  Print  |  Notify Moderator
Very interesting Mav. You always find this kind of stuff. I'll have to open/close mine tomorrow and take a look. I went outside and looked and our 2010 322TE has 5 springs and 7 connection points on the hinges.
2005 F250 PSD SB CC FX4 4x4 Reese 16k Slider
2010 Fuzion 322 Touring Edition
MadMav
Posted: 01/07/12 07:09pm Link  |  Print  |  Notify Moderator
Yeah, part of my job is trailer engineering design and being all out anal.
Mav
GT Roach
same
Posted: 01/07/12 07:10pm Link  |  Print  |  Notify Moderator
We first saw this electric lift on a Fuzion 5th wheel and liked the idea. After calling Lippert and getting nowhere we went through our local RV shop and had one installed. At first it worked OK but then would quit part way up and we'd have to lift it up manually after disconnecting the rod. We found that dispite the motor saying it was 6 amp in fact it draws 14 amp and doesn't get hot so it is working properly with a 15 amp breaker. I should note that our TH has the springs on each side of the door so we haven't had the related problem discussed here. In my experience the way the manufacterer handles these claims shows me what to expect and what to buy.
MadMav
Posted: 01/07/12 07:14pm Link  |  Print  |  Notify Moderator
I wonder if the installation was done correctly. Placement is very important to not overload or bind the actuator. So far, Keystone has done everything asked(including building me a new toy hauler in the past), just taking longer now becuause the local dealer is the middleman.
Mav
