RV.Net Open Roads Forum: do I need airbags for my F250 diesel
Search only in Tow Vehicles
 > do I need airbags for my F250 diesel
funpro
Danville, CA
Posted: 12/17/11 12:12pm Link  |  Print  |  Notify Moderator
I haul a 27ft Cougar. I have a 2008 F250 SuperDuty. Should I have airbags installs on the truck?
rasteck
Northern California/East Bay
Posted: 12/17/11 12:19pm Link  |  Print  |  Notify Moderator
If the rear sags enough that you want to level it out airbags are great choice. Infinitely adjustable and just let the air out when you don't have a load on the truck.
I wouldn't get them until I knew I needed them. :-)
JMHO
2000 Ram 2500 SLT/Laramie 24V CTD 2WD QCSB PacBrake, Smarty
2011 Colorado 320BS-FW 36'
EZ Flex + wet bolt
Curt E5 with R5 slider, Prodigy P3
Air Lift 5000's, Load Controller II
45Ricochet
North Idaho
Posted: 12/17/11 12:24pm Link  |  Print  |  Notify Moderator
Depends on your squat and if your coon huntin.
Do you have any weights to share with us?
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
powderman426
ohio
Posted: 12/17/11 12:28pm Link  |  Print  |  Notify Moderator
I have a 28' prowler that causes no sag. A 27 'er shouldn't cause any sag unless its a girlie truck
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
fla-gypsy
North Florida
Posted: 12/17/11 12:54pm Link  |  Print  |  Notify Moderator
You will not need them unless you overload the truck
rthibodaux
NewOrleans(Marrero), Louisiana
Posted: 12/17/11 12:57pm Link  |  Print  |  Notify Moderator
I installed helpher springs on my Dodge, no worry about air leaks, doesn't affect the ride, easy to install and cheaper than air bags.
AUWing
Slinger, WI
Posted: 12/17/11 01:12pm Link  |  Print  |  Notify Moderator
Hey - if you're looking to justify a gift from Santa then of course you need em - we'll stick up for ya. I'd say you want them to level the load and improve side to side stability
From someplace in SE Wisconsin
2011 Silverado 2500 Ext-cab / reg box / D/A
2008 Jayco Eagle 313RKS
2008 Goldwing
zedd
Arizona
Posted: 12/17/11 01:27pm Link  |  Print  |  Notify Moderator
Mine would squat an inch or so with the trailer hooked up. And it rode pretty rough, even for a truck, IMO. I put a set of Firestone Ride-Rites in it and it makes a world of difference. Levels the truck and the ride is much improved even when it's empty. Install is pretty easy too. Wife even remarked on how much better it was...she has a bad back and is pretty sensitive to a bumpy ride.
2008 Ford F250 Super Duty, Lariat, 6.4l PSD, Super Cab. Long Bed
2006 Jayco Jay Flight 27.5 RLS Fifth Wheel
alageezer
seale, al
Posted: 12/17/11 03:07pm Link  |  Print  |  Notify Moderator
My truck doesn't squat enough to need them, but my problem is the bumps transfering back into the truck. Also, went over a stretch of road recently that got the truck and trailer to rocking back and forth. The airbags should remedy these situations, shouldn't they?
2011 Bounder Classic
sirdrakejr
Las Vegas, Nevada
Posted: 12/17/11 03:35pm Link  |  Print  |  Notify Moderator
Moved from 5th wheels to tow vehicles.
Frank
