RV.Net Open Roads Forum: Tech Issues: Fridge Cools Just a Little
 > Fridge Cools Just a Little
TheCanuckian
Pierrefonds, Mooers Forks, Bushnell
Posted: 12/18/11 06:38am Link  |  Print  |  Notify Moderator
We have a Dometic fridge, 5 years old. It cools some, but not much. Have it on Coolest and it is enough to keep freezer below freezing, Popsicles mushy. It is on Auto, AC and Check light is on.
What do I check
Thanks all and a Merry Christmas to everyone !!
M
2008 Class A WindSport
Marc and Linda -2 Yorkies- LuLu and Lindy
Next year we will fill in UTAH !!! Maybe Alaska too !!!
Visit our Blog - The Canuckian
Ron3rd
Upland, CA USA
Posted: 12/18/11 07:13am Link  |  Print  |  Notify Moderator
M,
Does the problem happen on propane, on electric, or both?
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
robsouth
Near Atlanta, GA
Posted: 12/18/11 07:22am Link  |  Print  |  Notify Moderator
If check light is "on", it is not working properly. turn all off, wait ten minutes and turn back on to auto, be sure house power is connected and propane tanks are on and have gas in them. If check light comes back on, you have a problem that needs to be resolved by and experienced person.
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
pianotuna
Regina, SK, Canada
Posted: 12/18/11 07:49am Link  |  Print  |  Notify Moderator
Hi,
Try it on electric. If it works then there is a problem with the burner and/or propane supply.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
southernkilowatt
North Carolina
Posted: 12/18/11 09:00am Link  |  Print  |  Notify Moderator
"It is on Auto, AC and Check light is on."
Go to the back of the fridge and remove the outside panel. Where the fridge plugs in, verify that you have 120 volts. If you do not have a volt meter, use a lamp, a drill, anything that runs on 120 volts. If you do have 120 at the plug, remove the black cover on the back of the fridge and look at the two fuses. If they are good, then we will need more information to help you further.
Have you tried it on Propane? Are you level? when is the last time the unit was moved? Have you tried to "burp" it? what kind of unit do you have? whats the model number?
Good luck and let us know what you find.
Dave
Big Katuna
Deland, FL
Is the RV level? Has it ever worked properly? Did you recently add some warm items like a 12 pack or warm leftovers?
My Kharma ran over my Dogma.
Canuck1
Winnipeg, Manitoba, Canada
Posted: 12/18/11 10:46pm Link  |  Print  |  Notify Moderator
Had a similar problem, when running on gas, which in my case was caused by a "dirty" chimney. I solved the problem by going up on the roof, removing the chimney cover and then blew compressed air down the chimney. The debris exited near the burner so I had to clean the burner area before re-igniting. The fridge had been working great since.
2002 Triple E Signature A3607GW
300HP Cat, Allison MH3000
dougrainer
Carrolton, Texas
Posted: 12/19/11 06:07am Link  |  Print  |  Notify Moderator
Check light is a function of LP failure ONLY. On Auto, it will run on 120 if available. There is NO indication of failure on 120 other than NO cool at all. Clean the LP burner. Doug
TheCanuckian
Posted: 12/21/11 03:50am Link  |  Print  |  Notify Moderator
Thanks all who have helped. Turns out that there was a huge baseball size Mud-Dauber nest in the outside area where the burner is. Cleaned it out, vacuumed everything and now fridge is as cold as ever.
Thanks again !!
Joyeux Noel
