RV.Net Open Roads Forum: Class A Motorhomes: Norcold Fault Code LI oP
 > Norcold Fault Code LI oP
Linthead
Pennsylvania
Posted: 12/18/11 06:01pm Link  |  Print  |  Notify Moderator
Just had the recall work done on our Norcold. Now I have the fault code LI oP? What does this mean and is it an easy fix? Are the two things related?
Linthead
2007 American Coach Tradition 42V
2008 Hummer H3
Old-Biscuit
Verde Valley
Posted: 12/18/11 06:34pm Link  |  Print  |  Notify Moderator
"L1" "oP" fault - - high temp. limit switch open - - -
May be resettable It is located on the lower right area of the unit, just above where the propane flame & electric element are and against the side of the boiler.
With the most recent Norcold recall installed, go out and remove the external cover from the rear of the frig and see if the red LED is lit on the new high temp controller (black box). if so you need a new one installed. this is a very common problem, especially with the earlier versions of these black boxes used in the latest recall program. Call them back to change it out.
dougrainer
Carrolton, Texas
Posted: 12/18/11 06:37pm Link  |  Print  |  Notify Moderator
Go outside to the outside access door and look at the recall box on the lower coil. IS the red LED ON? if so the recall box has failed. Did the refer function after the recall was done? Doug
Linthead
Pennsylvania
Posted: 12/18/11 06:49pm Link  |  Print  |  Notify Moderator
Thanks for your help Old Biscuit - the red light is on the black box. So you are saying it needs replaced? Is this the part they just put on in the recall? If so, it is interesting how we NEVER had a problem with the refrigerator UNTILL the recall work was done?????
Old-Biscuit
Verde Valley
Posted: 12/18/11 07:50pm Link  |  Print  |  Notify Moderator
Recall box has failed.....get them to replace and then test refrigerator.
The recall....although a pain right now......is to prevent a problem that you are glad you didn't have.......FIRE!!!
I hate recalls especially when the recall is junk but what you going to do.
I think that products use to be tested thoroughly prior to being released......now a days seems release the product and then we see how it works [emoticon]
rvrepairnut
bc
Posted: 12/18/11 08:16pm Link  |  Print  |  Notify Moderator
people should first know what their talking about.The latest recall is Vertion D which has been out for 10 months or better and I have not seen or heard of one failing.
What happens that I have seen is the Tech mixes up the 12v IN and the 12 V out wires when installing the recall sensor device which causes the red lite to lite up and fridge to flash op.
rvrepairnut
bc
Posted: 12/18/11 08:19pm Link  |  Print  |  Notify Moderator
its not the fridge.Its either a failed sensor unit or most likely a incorrect wiring of the sensor recall installation
dougrainer
Carrolton, Texas
Posted: 12/19/11 05:58am Link  |  Print  |  Notify Moderator
The recall was to PREVENT overheating of the refer if you had blocked ventilation OR the cooling unit had leaked the ammonia. It is NOT a fire suppressant. You have to go to a Norcold Service center to have the recall box replaced. It will be under warranty. They will require that the Tech check out the refer before just replacing the box. The box could have tripped due to a cooling unit problem. Doug
rvrepairnut
bc
Posted: 12/19/11 11:11am Link  |  Print  |  Notify Moderator
DID? the Fridge ever work AFTER the recall for even a short while?
thats the 100$ question.I have seen where the Input and the output 12 volt wires are crossed when installing the Black box recall and it will give this code your getting.
dougrainer
Carrolton, Texas
Posted: 12/19/11 03:28pm Link  |  Print  |  Notify Moderator
You must be slow in Canada. Rev E has been out since the first of the summer. 50% of my failures I have seen are tech caused--Incorrect wiring of the recall. Doug
