RV.Net Open Roads Forum: Fifth-Wheels: motorcycle carrier
 > motorcycle carrier
Page of 5
wood207
florida
Posted: 12/20/11 09:46am Link  |  Print  |  Notify Moderator
Can I carry a large Harley Davidson (about 800 pounds) on the back of a 5th wheel or will it void the 5th wheel warranty? Does someone make lifts to carry big bikes on the back of a 5th wheel?
SH
Lynden, WA
Posted: 12/20/11 09:55am Link  |  Print  |  Notify Moderator
I believe it is much to heavy for a frame mount carrier and from what I read it will void most frame warranties. You would be better off to consider something like the Idaho Tote or the Swivel Wheel trailer in my opinion. Not sure if these won't even void a warranty.
Best Wishes.
2001 Alpenlite 35RK
2007.5 Chev LMM Duramax/Allison
BD Variable Vane Turbo Brake
TST 507
2010 FLHTC Electra Glide Classic Red Hot Sunglo ">
B.O. Plenty
Minnesota
Posted: 12/20/11 09:56am Link  |  Print  |  Notify Moderator
No way. The frame isn't designed for that kind of a load. Most companies won't even let you put a hitch on the back.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
45Ricochet
North Idaho
Posted: 12/20/11 09:59am Link  |  Print  |  Notify Moderator
B.O.
X2
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
Camps with Critters
Posted: 12/20/11 10:01am Link  |  Print  |  Notify Moderator
It will likely void your warranty, very few manufacturers allow this especially for a heavy bike. The rear portion of most 5er frames are only made to support trailer weight. Putting something that heavy on the rear can also adversely your pin weight, you need at least 15% of the trailer total on the pin for proper handling & control.
That being said there are options like a swivel wheel or Idaho tote trailer behind the 5er which reduces weight actually put on the trailer. If you go with one of these options be sure to find a good hitch maker that can create a hitch that helps spread the weight over a large area of the frame rather than bolting something to the rear of the frame.
Extreme option is doing something like I have done with a truck that carries a car and tows the trailer, granted it is a single purpose vehicle but I have less wrapped up in it than a new dually and it is way more capable.
05 Freightliner Century with Smart Car on the back
2010 Spacecraft 44.5 ft with a fully stocked bar-room
The Critters: Boogie & Jack (2 great dogs)
tkarvelis
Pittsburgh
Posted: 12/20/11 10:08am Link  |  Print  |  Notify Moderator
Might be able to carry it on the front of the truck.
jmtandem
western nevada
Posted: 12/20/11 10:10am Link  |  Print  |  Notify Moderator
This thread is interesting to me. I have a 30 foot travel trailer and am looking for a motorcycle carrier lift for the truck bed to carry a 700+ pound road bike. One reason I have the TT is to be able to carry things in the truck bed. I am interested in anybody that knows of a good loading device for the bike to load it into and out of the truck bed. Thanks.
'05 Dodge Cummins 4x4 dually 3500 white quadcab auto long bed.
Camps with Critters
Posted: 12/20/11 10:20am Link  |  Print  |  Notify Moderator
Yes, Click here!
jmtandem
western nevada
Posted: 12/20/11 10:27am Link  |  Print  |  Notify Moderator
Thanks, will look into Rampage ramps.
skylos
Columbus, OH
Posted: 12/20/11 10:28am Link  |  Print  |  Notify Moderator
http://www.mountainmaster.net/motorcycleloadingsystem.html
http://www.motorcycletrailer.com/rampage/
And there are more too. Google is your friend.
I've even seen one made of welded tubing and hydraulics that held the motorcycle level the whole time, a platform that lowered down to the ground behind the truck.
Page of 5
