RV.Net Open Roads Forum: Fifth-Wheels: Washer/dryer combo; vented vs. ventless
 > Washer/dryer combo; vented vs. ventless
Roadpilot
NH Seacoast
Posted: 12/21/11 07:20pm Link  |  Print  |  Notify Moderator
Vented units are the only way to go.
2006 Millennium Prevost
2013 Chevy Avalanche LTZ Black Diamond
2009 HD Electra Glide CVO Screaming Eagle - mine
2009 Yamaha VStar950 - DW
Cruiser Caddie motorcycle lift
BB_TX
McKinney, Texas
Posted: 12/21/11 08:27pm Link  |  Print  |  Notify Moderator
ArcticDodge wrote:
....May I ask question? When looking at used MH's with washer/dryers, how do you determine if the unit is vented or not as most units are snugly installed.
Should be a vent probably on the side wall just outside of where the W/D is installed inside.
eHoefler
ozark mountains
Posted: 12/22/11 06:07am Link  |  Print  |  Notify Moderator
Think about it a little bit. If you have a vent-less, where does all the heat and humidity go?? Humidity is a problem in the cooler months in any RV. In the summer, the A/C has to deal with the added heat and humidity. Definitely vented!
2010 Ram 3500, Crew Cab, Long bed, 4 x 4,Dually, Lights & Siren!
2006 40' Landmark Mt. Rushmore
docj
Fulltime--Home is where we park it
Posted: 12/22/11 06:51am Link  |  Print  |  Notify Moderator
The ventless dryers do not vent their humidity into the RV! They use a rather complex system that condenses the water vapor on an outer drum that is cooled with cold water. They use about 2 gallons an hour of cold water to do this. All the water just goes down the drain. We used ours all summer long without issue.
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2009 Chevy Malibu LTZ with ReadyBrute tow bar/braking system
Official WiFiRanger Ambassador WFRAMB303
Follow our adventures on Facebook at Weiss Travels
Delaine and Lindy
Linden Tn. (The View)
Posted: 12/22/11 08:02am Link  |  Print  |  Notify Moderator
I haven't owned a ventless Dryer, however common sense should win out in this situation. Most all RV hold moisture inside and moisture is a killer. Vented outside the RV helps to remove the moisture.. We are happy with the 5er we have it allows us to use the side by side Washer/Dryer (Whirlpool) and its vented same as the stick house. I also highly recommend the Stackable W/D. We have owned the Combo unit and it did work but you had to do small loads and it was time consuming... Good Luck with your choice.. Happy Trails.....
2012 Chevy Silverado 3500HD DRW's LTZ ******Traded******
Trailer Saver Air Ride (SOLD) (Sold)
2010 Mobile Suites 38 RSSB 3, with vanity slide (SOLD)
"Montana" our Sweet Furr Kid
12/21/10 "RIP" miss you!!
We are BLESSED!!!!
John & Angela
Full Timers in Canada, USA and Mexico
Posted: 12/22/11 08:10am Link  |  Print  |  Notify Moderator
remoandiris wrote:
gbopp wrote:
our next one will be vented.
If you can find them. That is a problem I have run into. New models are ventless.
Nah. We just replaced ours after 8.5 years of faithful full time use. (Read one load every day for 8.5 years)
Ordered it monday, arrived on the truck delivered to the door tuesday. 1075 bucks. 2100 XC Vented. (corrected on edit)
* This post was edited 12/22/11 08:59am by John & Angela *
2003 Revolution 40C Class A. 2002 Vanguard 22 foot Class C. Diesel smart car Toad or pulling a 2009 Timeout Tent Trailer.
Life is not measured by the number of breaths we take but rather by the moments that take our breath away.
Suzanne and Brad
Oregon
Posted: 12/22/11 08:26am Link  |  Print  |  Notify Moderator
You are correct that vented dries fasted. We love our Splendid combo unit.
Happy Travels!
Suzanne & Brad
bstark
Ontario, Canada
Posted: 12/22/11 08:41am Link  |  Print  |  Notify Moderator
That's the very feature that makes them such a bad choice for any RV.
Think of that water wasted to cool the drum while hoping that it acts to condense the moisture out of the clothes whithin. The reality is that the clothes are usually removed still wet to continue drying inside the rig hanging from door jambs (don't ask) to add further to the humidity within the rig.
The industry will eventually get "spanked" for this wastage of water by campgrounds eventually banding together to ban these things from being used at all. They are the antithesis of "green" technology as you are using electric to wash the clothes anyway but you then use both electic AND additional water to dry them.
Campgrounds have some control over their costs by putting longer term renters on metered elctric but there's no way they can control the water usage from these items.
When doing any form of off grid camping and you wish to do a load of laundry these guys are completely out of the question. Your tankage is now tasked to both use and accept water for both the wash cycle AND dry cycle..
Today is just the tomorrow you worried about yesterday!
Robin'n'Marian
Edmonton, Alberta, Canada
Posted: 12/22/11 08:43am Link  |  Print  |  Notify Moderator
Ordered it monday, arrived on the truck delivered to the door tuesday. 1075 bucks. 2100 XC Ventless
John and Angela,are you sure that your 2100XC is Ventless, according to their website, the 2100XC is Vented, the 7100XCP is ventless.
To RemoandIris, here is the link to Splendide Combos http://www.splendide.com/splendide_wd2100xc.htm
and this is the link to the brochure http://www.splendide.com/XC_RV_2pg_Brochure.pdf
roster2
Enid, Ok
Posted: 12/22/11 08:49am Link  |  Print  |  Notify Moderator
My 2100XC is vented, the only way to go!
2012 Montana 3402RL
2009 GMC 2500HD CC Duramax/Allison 6 spd 3:73/1 gears
Bob-USAF (Ret) Barbara-Retired DeCA
Chaplain, Christian Resort Ministries, Int'l
No pets, just two beautiful granddaughters
