RV.Net Open Roads Forum: Fifth-Wheels: Bridge Clearance
 > Bridge Clearance
jims1
NC
Posted: 12/24/11 09:51am Link  |  Print  |  Notify Moderator
In NC on I-95, Its the Benson exit that is low. If you are 13'6 or over beware. I lost a radar unit off a boat that we had measured at 13'6 and we lost it. We were southbound in the outside lane.
'06 Ram with a Cummins
Tuned w/ EFI-Live
'09 36MAX1 Carrilite
Me, Alie, and Salie
cruz-in
Southern Maryland
Posted: 12/24/11 09:53am Link  |  Print  |  Notify Moderator
If you have an android device a very inexpensive RV GPS(about $25) is Copilot Live from the Android Market. It has an RV mode. Have limited use with it but on a few short trips it worked real well.
conmoto
Northern Illinois
Posted: 12/24/11 10:48am Link  |  Print  |  Notify Moderator
This is a pretty good source for low clearance and other travel needs...http://www.allstays.com/c/low-clearance-locations.htm
2oldman
Winchester WA
Posted: 12/24/11 10:56am Link  |  Print  |  Notify Moderator
MTPockets1 wrote:
a problem with bridge clearance in your travels or in campgrounds?
Yes. I've had wayyyyy more trouble with untrimmed trees than bridges.
Tree-trimming is last on the maintenance list for many parks. As Jack Horkheimer said "keep looking up!"
rvnutts
Hampton, Arkansas
Posted: 12/24/11 11:20am Link  |  Print  |  Notify Moderator
Couple of years ago, Garmin took us into downtown Mobile headed for the tunnel! We did turn around! Thanks goodness it was Sunday morning. We were newbies, had never been there before and Garmin was a new toy we were trusting. Now we know better. Lynn
Brian and Lynn
15 yr. old son Sam
2005 Chevy Silverado Diesel Crewcab 3/4 Ton
07 Outback Sydney Edition 32FRLDS
Allworth
Orlando, FL
Posted: 12/24/11 07:55pm Link  |  Print  |  Notify Moderator
Why would you not go through the I-10 tunnel in Mobile?? Full height semis and container carriers do it all the time. Clearance is 14' plus in all lanes. My Titanium is 12'-8" and we run it whenever we head West or return home. You ARE supposed to turn all propane off at the tanks, but unless you are carrying hazmat that is the only restriction.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Trucks Don't Have Sparkplugs"
Duck
Miami Lakes, Fl
Posted: 12/25/11 05:03am Link  |  Print  |  Notify Moderator
X2
We have used the tunnel several times.
Don
08-FORD F350 PSD
13 Bighorn 3055RL
hermy
clancy, mt
Posted: 12/25/11 07:20am Link  |  Print  |  Notify Moderator
2nd day out with our new Bighorn we encountered a tunnel in Washington state that scared us. According to the signs we couldn't make it but I watched the semi trucks sailing thru there with no problems. Not worth the risk. We found an alternate route that proved to be a very interesting detour so we were not sorry we did that. Do your homework before you travel that day, double check what your GPS tells you and error on the side of caution.
davonelson
Pensacola, FL
Posted: 12/25/11 11:09am Link  |  Print  |  Notify Moderator
Go to aitaonline.com and find their low clearances listings and of course use the truck setting on your gps.
Devocamper
West Haven CT
Posted: 12/25/11 11:32am Link  |  Print  |  Notify Moderator
you can purchase a POI database of low clearnce info and load it onto to your curent GPS garmin has a poi loader that is free , check out lowclearnce.com, it used to about $20 with free updates for a year, I have used it for a few years not all low bridges are in the data base but it is very helpful and cheaper than the trucker type GPS units
08 NU-WA Hitchhiker Discover America 339 RSB
07 Chevy 3500HD LT1 EXT Cab LB DRW D/A
 > Bridge Clearance
