RV.Net Open Roads Forum: Propane tank at temps below 40 degrees?
 > Propane tank at temps below 40 degrees?
old guy
Oregon (pronounced Or e gun)
Posted: 12/25/11 10:58pm Link  |  Print  |  Notify Moderator
OP didn't say -40, he said below 40
jswor
tok, alaska
Posted: 12/25/11 11:10pm Link  |  Print  |  Notify Moderator
My Bad, meant below negative 40. So sorry, but think I got an answer, use the 12 volt oil pan heaters we use on or trucks up here, should work.
Jim
pianotuna
Regina, SK, Canada
Posted: 12/25/11 11:13pm Link  |  Print  |  Notify Moderator
Hi jswor,
Tell me more about these 12 volt oil pan heaters?
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
jswor
tok, alaska
Posted: 12/25/11 11:21pm Link  |  Print  |  Notify Moderator
You can buy them at the auto parts stores in Alaska. They are of different voltage and have a double sided tape on them which sticks to the oil pan underneath the vehicle. They were of different shapes, rectangles. Several different sizes. Can get another kind for under the batteries. Can put more than one on for a larger vehicle. we run the cords to a multi outlet at the front and then plug the thing in at 15 or below if the unit is parked outside. Works like a charm.
MrWizard
Traveling
Posted: 12/25/11 11:36pm Link  |  Print  |  Notify Moderator
moved from technology corner
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
joe b.
Posted: 12/26/11 05:00am Link  |  Print  |  Notify Moderator
Not sure how long you have lived in Tok, but we were in Nenana Alaska for 13 years and the temperatures are much the same as Tok. By late March, the chance of -40°F temperatures is not high between the lower 48 and Tok. Since the OP mentioned "returning" to Tok, I am guessing the OP is outside for the winter.
The years we lived in Nenana we used propane for heating domestic water and never had it quit working. During the real cold spells, down to the -70°F range, it would take longer to heat water or dry clothes but would do it. Now at our stick house, I had a high pressure regulator on at the tank and ran 30 psi pressure to the house, underground, then once inside the house, I had a regular low pressure regulator at the 1/2 lb pressure rating. If we had enough snow on the ground, I would try to keep some shoveled up around the 300 gallon tank we used. At the super cold temperatures the ground tends to stay warmer than the air so the tank can stay a bit warmer if snow covered. Would not apply to an RV propane tank though. The cab heater should keep most RVs warm enough to drive even if the propane didn't work. Just keep the RV winterized and no water in the tanks and you should be OK. You can always stop at a road house to spend the night if needed and can't sleep in the RV.
Moisture, from the fuel, freezing in the regulator on an RV tends to cause more problems than will the actual propane not vaporizing.
Most years we would leave our RV parked and winterized till mid May, give or take a week or two. From March on, the weather normally is great for snow machine trips, dog team trips with tent camping or aircraft flying on skis. Never had time to play with our RV till later in the year, about the same time the river boat came out of storage. LOL
On edit: All of the heating pads/tanks/freeze plugs, I had for my vehicles were 120 volt, not 12 volts. Most vehicles the are used in the Interior of Alaska will have a 120 V extension cord on the front to be able to plug in. If a person can find a 12 volt pad of some sort, I guess you could run it off the alternator while driving. A few of those and running the furnace at night would have caused me to have had a depleted battery by midnight. LOL Most campgrounds will be closed in the north in March so finding electric plug ins may not be easy.
* This post was last edited 12/26/11 08:52am by joe b. *   View edit history
joe b.
Stuart Florida
Formerly of Colorado and Alaska
Chevy 3500 DRW Dmax CC - Rockwood 8281 SS 5th Whl & 2008 Lance 845 TC
www.pajbcooper.com web site
Alaska Trip 2011 posted
Colo-Utah-Ariz 2012 trip posted
"Without challenge, adventure is impossible".
jetboater454
Camping or home
Posted: 12/26/11 05:13am Link  |  Print  |  Notify Moderator
Never heard of propane freezing.Guess they better warn the people up north in snow country that their outside propane tanks will freeze.Mine never had a problem when I lived in Ohio.
"If momma not happy ....Who cares.I have my TH AND my toys .
2007 Gulfstream Endura Max 40
2001 Polaris Ranger 4X4
Mod Pics
kennethwooster
Perryton Tx USA
Posted: 12/26/11 06:19am Link  |  Print  |  Notify Moderator
This a problem I've never heard of. All my life heated houses, ran pickups on propane. We can get below 0 in the Texas Panhandle. I've seen as low as neg. 24. Propane did not freeze, and nobody worried about it. If this is really a problem it I would want to know more.
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F250 2011 model, 4X4, King Ranch.
18K SuperGlide Hitch
pianotuna
Regina, SK, Canada
Posted: 12/26/11 06:37am Link  |  Print  |  Notify Moderator
Hi all,
It is -40 not +40 that he is dealing with. Propane ceases to vaporize at -42 C (-44 F). No vapor, no pressure, no heat.
Hi Jim,
You may need to do some other things as well. There is lots of good information in this thread:
Winter Camping
tomthyme
Flower Mound, TX
Posted: 12/26/11 06:49am Link  |  Print  |  Notify Moderator
You guys have had very different experiences than I have. While normal furnaces or fridge on propane have never. Caused a problem, I had a tank freeze up yesterday. I was in Waco TX at +44 F and had 1/2 a 40lb tank get covered in ice. The result was a end to the fuel flow. My engineer brother-in-law ( after all it was Christmas day ) tells me it had something to do with the speed with which the propane was being pulled from the canister. He.rattled about some "heat exchanging" stuff which I tried to listen to, but kids were crazy...well you know. The fuel draw was mainly a 5500 Onan fueled by LP. I know this thing burns fuel fast....but that fast?
We refilled at Flying J and the frozen tank only took half the volume of the empty ( non frozen ) tank.
Any ideas? Did my brother-in-law nail this one? If so, hog did the freeze up happen? Shouldn't the regulator manage the draw rate?
Merry Christmas everyone!
