Entropy69
Ohio
Hello all.
I'm about to move down to Florida and will be renting a u-haul vehicle trailer to tow a 3700 pound vehicle behind my RV. Anyone done this before and any special considerations I should be concerned with?
2007 Four Winds 5000 28A
Chevy Workhorse Chassis, 6.0L Vortec
GrumpyandGrandma
CIncinnati, OH
Entropy69 wrote: Hello all.
The only issue would be the rating for your hitch (3,500/5,000) and the GCVW for the MH.
Grandma in front of her retirement home..
She lets Grumpy drive!!
j-d
Sunny Florida USA
Be careful here, please. The UHaul Car Hauler weighs 2200# empty accordig to their site. If your vehicle weighs 3700, that's 5900 behind your coach at the very least. Ford E450 chassis allows towing 5000 but I think yours might be 3500. That puts you half a ton over the limit of a beefier vehicle, right at two tons over the rating of yours if I'm right at 3500.
I have the feeling you're going ahead with this regardless of cautions. You'll need the car hauler to apply some tongue weight to the rear of your coach or it'll try to wander. That load multiplies into the rear axle loading because of the length of a Class C overhang. You won't be able to carry much weight inside the RV, and its positioning (what fliers call Weight and Balance) will be critical. By the time you get the car hauler to not whip behind the RV, you may find the RV's rear axle over weight AND handling compromised because weight on the rear lightens the front axle.
God Bless, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100
Ken & Barbie
New Boston, MI, USA
Another point - drive slower this will keep the sway down alittle but overloading is still a concern.
Ken & Barb
Dusty R
Charlotte Michigan 48813
If you can go to a weight equalizing/distribution hitch it will handle much better.
Dusty
fisher60
Plant City, Florida
Have you concidered a Tow Dolly instead of the Car Trailer? A lot less weight. My 28A receiver is rated at 5000 lbs, 6000 with a WD hitch.
'01 Dutchman Express 28A, Borg Chrome Dually Valve Stems, Pacific Dualies Wheel Simulators, '06 Tuscon, '06 FLHTC/I
Good Sam Life Member
atreis
IN
Last winter I towed a '56 Thunderbird on a UHaul trailer. I pulled it using a UHaul truck since I don't have a capable enough vehicle of my own. As someone else indicated these trailers, empty, are VERY heavy. They also don't come with any sort of WD or sway control.
At 3700 lbs, you'll almost certainly exceed the weight capacity of your receiver after adding in the trailer weight.
An additional concern: The engine of the vehicle is on the front (tongue) of the trailer, and the trailer's wheels are fairly far back. This configuration works well if the truck is over-sized (like the UHaul trucks are) since the heavy tongue makes for more stable towing, but would be a nightmare on your RV which likely is not configured for anywhere near that kind of tongue weight.
Options:
As someone else suggested, rent a tow dolly. They're lighter overall, and the vehicle weight is all on the ground.
Another option would be flat tow it. This would mean getting a tow bar and having someone install the connector doohickies (technical term ) needed to hook up the car, but it could actually end up being a less expensive option (assuming the car doesn't require other modifications) than renting a dolly due to the distance (FL to OH). Not all cars can be easily flat towed though.
2009 Trail-Sport TS21RBH
2008 Toyota Sienna
Vet Man
Ct. & Florida
Does your class C have a brake controller? How will you stop all that weight?
2008 Itasca Sunrise 35A
2008 Honda CRV Toad
2010 ZR1 Colorado Toad
2013 Honda 150 PCX Scooter
2012 Honda Ruckus Scooter
"We Traveled To Alot Of Different Places While On Vacation, Until The wife Asked Directions"
rjstractor
Auburn, WA
Vet Man wrote: Does your class C have a brake controller? How will you stop all that weight?
UHaul trailers have surge brakes. Even so, that's a lot of weight for that rig.
carringb
Corvallis, OR
Besides hitch limitions, I'm pretty sure that will put you well over your GCWR of 16,000 pounds.
Bryan
2000 Ford E350 DRW Wagon (14-pass all captains chairs)
V10 w/ Banks PowerPack, Diablo Predator, 4.56 LS, ~350,000 miles
New Desert Fox in the works!
