RV.Net Open Roads Forum: Class A Motorhomes: Norcold "No A/C" Alarm
 > Norcold "No A/C" Alarm
JDelauter
Leesburg, FL, USA
Posted: 12/28/11 07:55am Link  |  Print  |  Notify Moderator
Traveled cross-country with reefer on LP. Sat for two weeks with the same. Ginally got to site with hook-up and when I try to put the fridge on "auto a/c" it switches and within 15 secs I get the "no a/c" alarm. Any suggestions to prevent me driving one hour to a Camping World?
Retired SMCM(MDV) USN 30 years
3 'Nam Tours
As of 11/04 Full-Timing with:
2003 Gulfstream Friendship, Quad slide
1 lovely wife
and 1 sassy Bichon
JDelauter@aol.com
wilpower
Posted: 12/28/11 08:01am Link  |  Print  |  Notify Moderator
Check the outlet, maybe GFI tripped? or breaker?
Wil & Cyndi & Einstein (African Gray)
JDelauter
Leesburg, FL, USA
Posted: 12/28/11 12:56pm Link  |  Print  |  Notify Moderator
VOILA!!! It was, in fact, the 5amp glass fuse behind the black cover. Now running perfectly. Thank all of you so much for your input and guidance. Jack
hottubkid
SCHAUMBURG,IL
Posted: 12/28/11 08:05am Link  |  Print  |  Notify Moderator
Put it on gas untill your ready. Check the breaker.If not most likely the heat coil
hottubkid60193@yahoo.com
2004 SOUTHWIND 36E Tow 2003 CRV
southernkilowatt
North Carolina
Posted: 12/28/11 08:22am Link  |  Print  |  Notify Moderator
Go outside and pull the refer cover off. Unplug the refer from the 110 outlet and test the outlet. Use a volt meter OR a lamp, hairdryer, anything that has a cord and uses 110. IF you DO NOT have voltage at the outlet, then go backwards, and start checking breakers, GFCI's (although it should not be on a GFCI) but you never know how it was wired. Turn each breaker ALL The WAY off and back on to "reset" them. Go back and check the plug.
IF YOU DO have voltage at the plug, then look on the back of the refer. Find the black box cover and remove it. Inside you will find 2 fuses, one for the 12volt system and one for the 120 volt system. Check each one. If the fuses are good then suspect either the heating element or the board and will require a trip to a dealer. Good luck and let us know what you find.
Dave
doc brown
Redondo Beach, CA,
Posted: 12/28/11 10:32am Link  |  Print  |  Notify Moderator
Mine did that, followed several days later by no power. Tossed it and installed a residential fridge. Good luck.
Steve,Kathy,Josh & Morpheus the Basenji
2004 40' TSDP Country Coach Inspire DaVinci
350 Cummins, 3000 Allison
2008 Wrangler X Rubicon/Blue OX Tow Bar/Ready Brake
JC2
Mo
Posted: 12/28/11 02:10pm Link  |  Print  |  Notify Moderator
Fuses blow for a reason. I would try and determin the cause. You don't need to have it happen again and not catch it as spoiled food would not be pleasant.
2004 Newmar DSDP 4015,370hp Cummins ISL,Spartan MM Chassis,2008 Saturn Vue,FMCA #402879,NKK 19776
southernkilowatt
North Carolina
Posted: 12/28/11 03:32pm Link  |  Print  |  Notify Moderator
I very much agree with this statement. However, we may never know what the reason is. I have replaced fuses and never had them blow again. I always check with a meter to try and figure out why a fuse blew, and often find a short, or very high resistance. But sometimes you just have to shake your head and say "its a bad fuse"
Dave
