RV.Net Open Roads Forum: Fifth-Wheels: Tool Box in Bed While towing 5th wheel
 > Tool Box in Bed While towing 5th wheel
Page of 5
R12RTee
Full Timing out of Sarasota, FL
Posted: 12/28/11 09:31pm Link  |  Quote  |  Print  |  Notify Moderator
I have a UWS toolbox behind the hitch. I mounted it on slides because the tonneau cover prevented opening the cover but it's better since I don't have to stretch so far for tools.
2013 DRV Mobile Suite
2013 Ford F-450
2011 BMW R1200RT
SoCalDesertRider
SanDiego, CA, USA
Posted: 12/28/11 10:51pm Link  |  Quote  |  Print  |  Notify Moderator
So long as your truck has plenty of rear axle capacity, there shouldn't be a problem with the box in the rear of the bed. If your truck is already too small for the hitch weight, adding more weight behind the axle won't be helping the truck any...
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
RCMAN46
NorthWest
Posted: 12/28/11 11:08pm Link  |  Quote  |  Print  |  Notify Moderator
korbe wrote:
I use a utility box that rests on the rails and sits up about 2" above the rails. 5th wheel rides just fine & I like the ability to put things under the box as well.
X2. With this box I can still haul a 4x8 sheet of plywood and still have all my tools with me when I do not have the 5th wheel hitch in the bed. When I do have the 5th wheel on there is some room under my tool box for things like tire chains and a plastic storage box that I can put most anything in that will fit.
sirdrakejr
Las Vegas, Nevada
Posted: 12/28/11 11:36pm Link  |  Quote  |  Print  |  Notify Moderator
I agree. I used one from Checker Auto that was a low profile rail box that still allowed about 5" of space under it where I stored blocks and other things useful for 5-ing. I also carried a genset in front of the toolbox and STILL had plenty of room for the 5th wheel hitch. It also put all that extra weight sitting between the front and rear axles.
Frank
wild acres
Brandenburg, Ky 40108
Posted: 12/28/11 11:48pm Link  |  Quote  |  Print  |  Notify Moderator
I got one at home depot, that sets in front of the hitch, it sets on the bed of the truck, not the rails. Wanted to be able to see hitch to hook up. At least by buying at a big box store, more to choose from and you can take it out and see if it serves the purpose for its use. Very happy with it, haul the little propane bottles, and lawn chairs in it, and keeps them out of the weather.
John Ret USArmy
Jake (soft haired Wheaten terrier)
12 Ford F-250 6.7 PSD 4 x 4
05 Cardinal WBLX 29'
MPI_Mallard
McGregor Ontario,St. Cloud Florida
Posted: 12/29/11 06:36am Link  |  Quote  |  Print  |  Notify Moderator
Iv'e got a low-profile tool box up front with a retrax tonneau and my factory tail gate so i can lock the whole she-bang up,i considered the rear box but now that wer'e full-timing i like having the space in the rear of the bed for groceries and such much like the trunk of a car also i found that due to weight=more fuel costs i learned to really consider what i really need to carry around. All that goes into the truck is truck related,air compressor,jack and stands,cheat-bar,sockets,car wash brush,spare fuel/gas cans,oil and such,all trailer realated things stay in the trailer and so on. Believe me,i'm a major tool guy and it would be easy for me to load up with all kinds of******i don't need but there's a lot of truth in "Less is more".
07' Dodge 3500 6 speed Cummins Diesel Dually/6.7L Bully-Chipped /
Exhst Brake/07' Cedar Creek 37CDTSD Daydreamer fiver
Mallard @ Frau Blücher
Red Green:
Now lets Bow your heads for the men's prayer.
I am a man, but I can change.
If I have to, I guess...
hitchup
Fulltiming and on the Road.
Posted: 12/29/11 08:14am Link  |  Quote  |  Print  |  Notify Moderator
DH had a low profile, but would still bump into it if he misjudged the pin height when he backed-up. He got the front loading V-shape, similiar to link, but lost some of his storage room, especially for long items. But has never hit it over the last year and can see to backup easier.
Link
2009 DRV Mobile Suite 38TKSB3 (38RSSB3)....our custom home w/2011 upgrades
2010 Ford F450 KR CC 4x4......his office
Working Fulltimers since 3/2005
"Shoot for the Moon! Even if you miss it, you will land among the Stars."
Fire5er
Port Orchard, WA
Posted: 12/29/11 10:05am Link  |  Quote  |  Print  |  Notify Moderator
I purchased one from Home Depot that is flush mount (below the bed rails) almost as wide as the truck bed and almost as deep as the bed of my DRW LB F350. I got this box so I could put both Honda 2000w generators in it and lock them up to secure them when traveling.
2011 F350 CC, 6.7, LB, DRW.
Hijacker (24-UMS-21) 21k Underbox Hitch.
2007 Keystone Montana 3400RL (38'9")
PressurePro Tire Pressure Monitoring System.
Gunpilot77
Killeen, Tx
Posted: 12/29/11 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
Old-Biscuit wrote:
I purchased a Low Profile Tool Box from Highway Products.
I got the one for rear of box......called the 'Partner'
It sits low....can hitch trailer up and open box.
For has served me very well.......sturdy/weather proof/heavy locking arms/battery operated light and quite roomy.
I have had one for seven or eight years and consider it one of the best options I have ever purchased. I had to rest the gooseneck of a 3 horse trailer with full living quarters on it one time to adjust the landing gear. I placed the hitch on a 14 inch long 2X6 to spread the load and the lid held. After all these years it is still weatherproof and the lock and latches work perfectly. In addition it takes the place of a tailgate for loose items I store in the bed.
Fifth wheel pulled with a pick-up
DLW
Johnson City TN 37604
Posted: 12/29/11 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
I picked up a couple of heavy black plastic tool boxes at Lowes that fit like saddle bags - even with the top of bed rails - in the bed just behind the back doors. I can get it them with the rig on the hitch. lockable and look good after 6 years in the sun. Big enough for all the hand tools you can carry. Stay with the truck when we leave camp site. <$50 each.
Gean. Larry & Roxie
Chevy 3500 4WD/HD/DW Crew DuraMax Allison B&W Hitch
AVION 37 - W4AUE 146.52
Page of 5
