SCVJeff
Santa Clarita, CA.
So I'm out here filling the wheel bearing that the service guy left the plug out on (yes there was fortunately some left), and trying to figure out where it should be filled to? I think I remember the book that's not here saying fill to the bottom of the center plug????
I'm also thinking about changing the factory oil out to the much thicker Lucas Hub Oil on the remaining hub. I obviously need to drain the old oil out, but how anal should I get? Can I just open the fill hole and drain, or do I need to remove the entire reservoir?
Jeff - WA6EQU
fcooper
Richmond Hill, Georgia
You should fill to just below the plug opening.
Fred
Fred & Vicki
Richmond Hill, Ga
2000 Holiday Rambler Endeavor/Freightliner/330 Cat
2000 Honda Odyssey toad w SMI Silent Partner braking system
Tire Sentry monitoring system
Livin Good
On The Road
fcooper wrote: You should fill to just below the plug opening.
Fred
Yep that's a simple one....
wolfe10
Wet hubs have a ring showing "fill to level". It will be just below the opening for the plug.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
SCVJeff
Santa Clarita, CA.
wolfe10 wrote: Wet hubs have a ring showing "fill to level". It will be just below the opening for the plug. It does, and the arrow is pointing to 3/4 full which didn't click in memory.
Now I need to find a replacement hub cap clip..... Wowaysme..
snickster
Guntersville , AL
Fleetpride stores carry the Stemco parts for my wheel hub covers.
I replaced the plastic cover and the plug for about $7 on Friday.
siphon the oil out or remove the 6 screws on the ring holding the
plastic cover and the oil will drain out . Refill with Hub Oil.
The snickster
Mark and Priscilla
98 HR ENDEAVOR 37 WDS Diesel
Jeep Wrangler Toad
THE YORKIES : Winston , Abby, Izzy
SCVJeff
Santa Clarita, CA.
Thanks!!
The right hub is full, and the left hub might get drained this weekend just so they're the same.
Last question: Anyone had to replace one of the wheel hub cap clips? Is that a NAPA type part?
edited 12/29/11 12:24am by SCVJeff *
