RV.Net Open Roads Forum: Dinghy Towing: Towing Escape With Reyo
Search only in Dinghy Towing
 > Towing Escape With Reyo
Suthy48
Tracy CA
Posted: 12/28/11 05:56pm Link  |  Print  |  Notify Moderator
Hello RVr's
Has anybody towed a Ford Escape Hybrid with an Itasca Reyo? I am worried about Total Gross Vehicle Weight and having enough power from the MB Turbo Diesel engine.
Thank You
Don
wny_pat
Western NYS
Posted: 12/28/11 10:06pm Link  |  Print  |  Notify Moderator
All the current Reyo models have the same weight ratings below.
GCWR *(lbs.) 15,250
GVWR (lbs.) 11,030
GAWR - Front (lbs.) 4,410
GAWR - Rear (lbs.) 7,720
Trailer Hitch *5,000-lb. drawbar/500-lb. maximum vertical tongue weight w/7-pin connector
* Actual towing capacity is dependent upon your particular loading and towing circumstances, which includes the GVWR, GAWR and GCWR as well as adequate trailer brakes. Please refer to the Operator's Manual of your vehicle for further towing information.
Base Curb Weight (lbs) of the Excape Hybrid front wheel drive is 3663.
“All journeys have secret destinations of which the traveler is unaware.”
