RV.Net Open Roads Forum: Dinghy Towing: Advice on 2012 Jeep Grand Cherokee
Search only in Dinghy Towing
 > Advice on 2012 Jeep Grand Cherokee
ploiselle
South Shore, MA
Posted: 12/30/11 08:28pm Link  |  Print  |  Notify Moderator
tropical36 wrote:
ploiselle wrote:
What does the owners manual say?
I wouldn't rely on a Jeep owners manual as they are a ways behind and the dinghy towing guides as well. The OP would be better served by having this posted in the Dinghy section of these forums where we have members that know, cuz they have been there and done that.
Didn't we already have this conversation a couple weeks ago?[emoticon]
Happy New Year
Paul
* This post was edited 12/30/11 09:03pm by ploiselle *
41' MountainAire (MADP) -Spartan- Cummins 350 ISC
2012 Jeep Grand Cherokee Overland
2004 Jeep Grand Cherokee Limited
Brake Buddy - CoachNet
JohnnyT
On The Road
Posted: 12/31/11 06:26am Link  |  Print  |  Notify Moderator
Moved from class A forum
dhansen871
Las Vegas
Posted: 12/31/11 08:53am Link  |  Print  |  Notify Moderator
Reading this post about how to tow the 2012 GC. My question is "Why does the key FOB need to be left in the ignition?" Also, I have a braking system that needs 12 volts to operate. I noticed that once I turn the vehicle off (as it says in the owners manual), the cigarette lighter does not have any power to it. Is this where it was written in this post where you need to have power from the Coach to the vehicle for power to operate the braking system.
Thanks
Dave & DW Jodi
Max the Cat (RIP)
SoCal Mountains and Las Vegas
2007 Country Coach 430 Allure
2012 Jeep GC Overland
tropical36
Southwest Florida_USA
Posted: 12/31/11 09:52am Link  |  Print  |  Notify Moderator
Happy New Year
Paul
Every conversation has been and will be done over and over again and like all education, it usually takes more than once.
As for the manuals, Dinghy guides and Jeep for instance, some and Wrangler for one, indicate from their instructions, that they still have a steering lock, which went out prior to the 2010 models, I think.
Happy New Year and to the instruction manuals as well! [emoticon]
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E__Spartan MM_06 400HP C9 CAT_Allison 3000
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
tropical36
Posted: 12/31/11 10:02am Link  |  Print  |  Notify Moderator
Thanks
Once you get that thrashed out, consider using a surge brake system from Demco that doesn't require any voltage. I would consider their complete system for your toad as well, if you don't already have usable equipment...READY BRAKE
sch911
Rochester Hills, MI
Posted: 12/31/11 12:17pm Link  |  Print  |  Notify Moderator
Thanks
For a 11/12 JGC the key fob is removed after the t-case is in neutral.
To power your accessories you can still get power from the center console power port (pretty sure). But you will eventually run down the battery. The best way to do this is power the supplemental systems from the tow vehicle. There is a pin in the 7 way connector for this purpose. Or the manufacturer of the supplemental system would provide a harness for this purpose also.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2007 Jeep Grand Cherokee Limited Toad
rdalcanto
Salt Lake City
Posted: 01/01/12 08:36am Link  |  Print  |  Notify Moderator
You have to use the FOB so you can turn the engine off, after you put it into Reverse to confirm that you are in Neutral, without going into Park first. If you go into Park with the engine still running, you will grind gears. If you do this with the push-button in, you can't turn the engine off while in Reverse or Neutral. You remove the FOB when ready to tow. Just follow the instructions in the manual.
DanLefoot
San Diego
Posted: 01/03/12 05:11pm Link  |  Print  |  Notify Moderator
sch911 wrote:
Ok I'm here! And thank you bsinmich...
First issue: If it's a 2WD or has Quadra Trac I IT CANNOT BE FLAT TOWED!
Assuming it's none of those then yes you need to follow the procedure in the Owners Manual found in the "Recreational Towing" section for how to put the transfer case into neutral. And yes it will require removal of the Start/Stop button (very easy), then placing the key Fob into the switch directly. This is part of the process. You will be able to remove the key fob at the end of the process.
Any questions?
I bet you know how the Wrangler works as well. I wrote to the Jeep customer service dept and they told me to ask the dealer. Not much help there.
Can I assume the 2012 Wrangler does not have a locking steering column? So with transmission in park and transfer case and neutral I can remove the key. Correct?
Owners manual says to leave the key in the acc. position and remove the negative battery wire. Any idea why Jeep would say that if the steering column cannot be locked?
Thanks.
Dan
tropical36
Posted: 01/03/12 09:04pm Link  |  Print  |  Notify Moderator
Any questions?
Thanks.
Dan
We'll wait on our expert for confirmation, but I can tell you now, that it's because the manual and consequently the dinghy charts haven't been updated in that regard since 2010 at least. I'm thinking that the steering wheel lock was discontinued sometime in 2009 and the 4WD system is command trac.
NorCal_Monaco
Santa Cruz
Posted: 01/09/12 10:17am Link  |  Print  |  Notify Moderator
Hey all with Jeep Grand Cherokee and plan to tow it - WARNING.
I just took delivery of a 2012 Jeep Grand Cherokee Overland with the 3.6l Pentastar motor. 200 miles on it now.
Had my Blue Ox gear installed, etc, etc.
I just towed the Cherokee from NorCal to San Diego on 1/8.
I followed the tow procedures exactly, and have been towing four wheel drive trucks for years. All very similar procedure; engine off, stick to neutral, press the neutral transfer case button, stays solid, start the truck, move the lever to reverse/drive to make sure it is disconnected, shut off motor and put in park, E-brake off. And with the Key and Go system, you remove the FOB from the hole (which btw is totally freaky for me but ok it worked fine; no steering lock).
Here is the issue. I stopped 300 miles into my trip and decided to cycle the transmission like you would other tow vehicles that cannot be towed long distances (just for prosperity sake to make me feel better). When I got into the vehicle I notice a rubbery burning smell, non-electrical. So I did my cycle to flow fluids and got everything back to normal tow position.
Hauled the Cherokee the rest of the trip to San Diego. When I disconnected, smell was stronger, especially when running the truck. Its origin is outside the vehicle and from the engine compartment as best as I can tell. I have smelled this before when towing my H2 and thought it was just tires not tracking perfectly.
The problem is I now notice a droning sound of sorts when driving the Cherokee that is unusual, a whirring revolution sound at around 2k rpm.
I have not driven the truck that much and I am questioning myself if this is a condition of the vehicle from towing or something that I did not notice before with the drive train. It is very noticeable.
I suspect I am going to drive it for a few days and see if it hangs around and then take it in to Jeep to have them investigate.
Jeep clearly advertises and supports flat towing behind RVs on the QII trucks. Even announced how the new transmission with the Pentastar has a special pump that flows fluids when towing.
FYI.
