RV.Net Open Roads Forum: Tow Vehicles: F-350 quit running won't start
Search only in Tow Vehicles
 > F-350 quit running won't start
Wayne Fogle
Etters Pa.
Posted: 12/30/11 05:57pm Link  |  Print  |  Notify Moderator
I have a 1997 ford F-350 with a 7.3 power stroke about a week ago went to start it the batteries were low I charged them got it started drove it sunday and monday morning in the after noon if stopped running had it towed to the house today replaced the batteries and the glow plug regulator new max 30 fuse and went to start it blew the fuse right away as soon as I turned the ignition switch on thank you for any help you could give me!
Tankcar
Santee, California USA
Posted: 12/30/11 06:14pm Link  |  Print  |  Notify Moderator
Sound like it mabe be a starter of starter solenoid? Assuming what you have alredy done was correct? What did the 30 amp fuse protect/ feed?
robwen
NE OH
Posted: 12/30/11 06:26pm Link  |  Print  |  Notify Moderator
Try unplugging the fuel heater. I had a dead 7.3 once and the fuel heater was on the same fuse that caused the no start condition.
Rob a.k.a 69oiler
'03 Ford Excursion V10 4x4 3.73 XLT
'98 SunnyBrook 30DB
'05 Continental Cargo 16'x8' enclosed 9950 GVW
Former Ford IDI and 7.3 PSD guy, hope to get back into a diesel someday.
Home Skillet
Pearland Texas
Posted: 12/30/11 07:16pm Link  |  Print  |  Notify Moderator
My bet also.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,SmarTire,Bilstein Shocks,Trans temp guage,Lowrace iWAY
nremtp143
Georgia
Posted: 12/31/11 07:47am Link  |  Print  |  Notify Moderator
Home Skillet wrote:
My bet also.
X3..
2012 Sandpiper 365SAQ, Goodyear G614s, TST TPMS
2010 F350 DRW 6.4L 4x4, Edge CTS, B&W Companion, Viair 10007 air system, Firestone Ride-Rites,Flo-Pro cold air pipe
2001 Excursion Limited 7.3L 4x4, V/B Springs
2001 Silverado 3500 DRW CCLB 8.1L/Allison 4x4
gijoecam
Midwest
Posted: 01/01/12 12:23pm Link  |  Print  |  Notify Moderator
Ditto. To expand on that a bit, there is a heater in the bottom of the fuel filter/separator housing. That heater often will short to ground, blowing its fuse. IIRC, that fuse also powers the PCM. The short-term fix is to disconnect the heater (a plug on the bottom of the separator), replace the fuse, and it *should8 fire back up (if that's the problem). Long term solution is, of course, to replace the heater (which IIRC is available separately and not very expensive).
Good luck!
