RV.Net Open Roads Forum: Fifth-Wheels: Stability - Quadra BigFoot Hydraulic Levelers
 > Stability - Quadra BigFoot Hydraulic Levelers
RECVEH2005
Green Valley, AZ, USA
Posted: 12/31/11 10:20am Link  |  Print  |  Notify Moderator
To those who have the 4 Quadra brand BigFoot levelers on your fivers:
Is your fiver stable when parked? By this I mean does your fiver shake when you move around in it? Or do you find that you need to use stabilizing jacks in the rear and/or a tripod under the pin to keep it steady?
Mike
Mike & Donna Scheer
2013 GMC SRW Crew Cab 3500 short-bed D/A
2013 HitchHiker Discover America 300 FK
signalrat
MO, USA
Posted: 12/31/11 11:00am Link  |  Print  |  Notify Moderator
Yes, not much, no.
2006 Ford F350 DRW King Ranch CC 4x4 6.0PSD Banks Economind & BanksIQ & Banks Speedbrake Timbrens Bilsteins
2010 Carriage Cameo 36FWS
Rossey
Appomattox, Virginia. / Rockville, Maryland
Posted: 12/31/11 01:53pm Link  |  Print  |  Notify Moderator
Extremely stable. I DO NOT need any other stabilization with my "Big Foot's" & I have a 40 ft 5er with 4 slides. Great product..... go for it ! http://www.quadraleveler.com/levelingsystems/fifthwheels.php
Jim-n-Henri
Charleston SC
Posted: 12/31/11 02:10pm Link  |  Print  |  Notify Moderator
I have the Big foot system and can feel some movement...thinking about some stabilizers.
thomasmnile
Deltona, Fl.
Posted: 12/31/11 02:13pm Link  |  Print  |  Notify Moderator
A little movement, but not annoying or bothersome. After all, the trailer still sitting on 4 air filled rubber tires. I have Wayne's stabilizers, but seldom use them; I generally just extend the rear stabilizer jacks and that calms any "butt" wiggle in the trailer.
R-D
Arroyo Grande, CA.
Posted: 12/31/11 09:03pm Link  |  Print  |  Notify Moderator
We have the Quadra Big Foot levelers and LOVE them. We already had Steady Fast stablizers and Rotochocks for each tire. But I have to say that after adding the Quadra levelers we noticed that almost all movement is gone. Very stable now. 38ft 5th wheel with four slides. We wonder why we waited so long to get the Quadra Big Foot, (I know $$$) but money well spent. Love them.
Dutch & Di
Livingston, TX
Posted: 12/31/11 10:59pm Link  |  Print  |  Notify Moderator
We already had our permanently mounted stabilizers on our Carriage for 4 years before adding the BF system 2 years ago.
While the BF does help with stability, it is a leveling system. We tried it first without tightening our stabilizer knobs. While the system helped some, the movement was eliminated when we tightened our stabilizer knobs. We are now movement free. Diana
1996 Dodge Dually, Max Brake Controller, Mor/Ryde Susp Rear Spgs, Air Bags, Tailgate Easylift,
1996/2010 Triple Slide Carriage, Mor/Ryde Susp, Kodiak Disc Brakes, Big Foot Auto Leveling System, TST TPMS
Traveler II
Minnesota
Posted: 01/01/12 07:34am Link  |  Print  |  Notify Moderator
The Big Foot system is not as stable as I thought it would be,(not all that bad) but I like how simple it's to set up and am not planning to add anything at this time.
2011 Cameo 34SB3
2008 Chevy D/A, Smartair Air Springs, Trailer Saver BD3 Air Hitch, Mor/Ryde pin box, IS Suspension, Disk Brakes
Nights Camped in 2011 - 165
Nights Camped in 2012 - 142
Nights Camped in 2013 - 101
kennethwooster
Perryton Tx USA
Posted: 01/01/12 07:47am Link  |  Print  |  Notify Moderator
We love the big foot system. Makes setting up so easy. Yes there is some movement but much better. We do use Roto Chocks, and Tri Pod stabilizer. We had the stabilizer so we still use it. I would use Roto Chocks regardless.
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F250 2011 model, 4X4, King Ranch.
18K SuperGlide Hitch
pcm1959
home
Posted: 01/01/12 08:14am Link  |  Print  |  Notify Moderator
Our Cameo is a shorter unit with 3 slides and there are only 2 of us. You can feel about as much movement as we felt in our previous fiver with out the system. However, the pin box tripod helps a lot. The tripod pretty much eliminates the movement in the front where the bed is located. That way, if one of us gets up in the night, the other is not disturbed. Not a problem during the day. Phillip
2011 Silverado Crew 3500 SRW Duramax/Allison
2011 Carriage Cameo 31KSLS
Jacksonville, FL
