RV.Net Open Roads Forum: Fifth-Wheels: Landing Jacks
 > Landing Jacks
swbouton
Hampstead, NC
Posted: 01/02/12 10:16am Link  |  Print  |  Notify Moderator
I followed a pink wire that goes from the switch and runs to the area behind the battery. There is a black "block" on it that looks like it might have a fuse in it to me. I am attaching a photo.
I don't want to break something else. Is the black "block" a fuseholder or am I way off track?
This is a 2010 Springdale.
Thanks to all for your help.
Alpenliter
Fulltimer: Wherever we are!
Posted: 01/02/12 11:04am Link  |  Print  |  Notify Moderator
That's it!!
My first Wife Linda, 45+years
2004 F-450 CC, DRW 6.0 Classy Chassis Upgrade
Bulletproof Diesel upgrades
1997 33' Alpenlite
400 Watts Solar
Lifetime Good Sam Member #39644174
Escapees SKP#89882
Vietnam Vet '67-'68
Extreme Makeover RV Style!
Allworth
Orlando, FL
Posted: 01/02/12 11:07am Link  |  Print  |  Notify Moderator
Pop it open. It holds a large version of an automotive blade-type fuse. Usually 30 Amp, although it could be 50 Amp.
Pull the fuse and test it with an Ohm-meter. It will either read near zero or 10,000 Ohms. It is probably blown (high resistance) since it is on the master power feed to the jacks. Autozone or O'Rileys has replacements.
Why it may be blown is a whole nother can of bait.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Trucks Don't Have Sparkplugs"
swbouton
Hampstead, NC
Posted: 01/02/12 11:59am Link  |  Print  |  Notify Moderator
I'm amazed and thrilled with all the support I am getting. Maybe I can be of help once I learn a lot more about RV-ing.
The fuse reads 0.000, so I am off to buy a few. The jack may have been raised too high. Could that have blown the fuse?
Thank you,
Steve
greende
Syracuse,NY
Posted: 01/02/12 01:08pm Link  |  Print  |  Notify Moderator
Steve,
It looks as though you found it. Yes, pulling the landing gear up too high can blow the fuse. As some have stated, Put a mark or piece of tape on the leg to indicate the highest it will go without blowing fuses. Good luck.
2011 Chevy 3500 HD LTZ Duramax/Allison Crew Cab Long Box DRW
B&W Turnover Ball with Companion
2012 Keystone Cougar 293 SAB 5er
jpmason
Fredericksburg, VA
Posted: 01/02/12 01:35pm Link  |  Print  |  Notify Moderator
Thank you,
Steve
Hmmm, if the fuse is reading 0 ohms then it is good. Mine just had a bad connection and after reseating the fuse the jacks started working. If reseating the fuse or putting a new one in don't work, I would start tracking down where the 12 volts is and is not.
2007 Ford F250 6.0 PSD
2012 Sundance 3300CK
GaPete
Georgia
Posted: 01/02/12 01:42pm Link  |  Print  |  Notify Moderator
What JP said X 2. Use the meter you apparently have and find out where you do/do not have 12v. The point between the have and have not is your problem.
swbouton
Hampstead, NC
Posted: 01/02/12 03:20pm Link  |  Print  |  Notify Moderator
The CASE is almost closed. It was the fuse and replacing it did resolve the problem. Now I'll get some reflective tape and mark the legs.
I didn't think about it but the electrical run from the house to the camper is a poor one. I'll address that in the near future.
Thanks, again, to all of you. You're a great group!
Steve
jpmason
Fredericksburg, VA
Posted: 01/02/12 04:06pm Link  |  Print  |  Notify Moderator
Glad to hear it. I think I'll mark my legs also. That sounds like a good idea.
 > Landing Jacks
