traindriver
illinois
I just put air bags on my truck and have been playing around trying to get a better ride. I have a gmc 2500 cc lb, with about 2200 pds of pin weight. For those of you with similiar weight and air bags, how much air do you carry? Thanks.
CamperJack
Kingsley Ia U.S.A.
I carry 35 to 40#. Gives a nice smooth ride & runs level.
1997 Excel 5th wheel 331/2ftr
1991 Ford Western Hauler
My own camping club (North Central Gad A Bouts)
B.O. Plenty
Minnesota
I use just enough air to level my truck. Airbags aren't designed to carry extra weight just as it says in their directions. I run around 15-20 PSI when hitched up. If I put in too much air it rides like a errrr.. a truck.
B.O.
2011 Big Country 3250TS...2010 Ram CC Laramie 4wd Cummins
15k Super Glide, Firestone Ride Rite, TrailAir Tri-Glide
Michelin XPS Ribs. Just say no to Chinese tires.
Twin Cities Mn.
John3872
Iowa
I run 35 psi when hooked up then drop it to 10 psi when empty.
2003 Chevy 2500HD Duramax Crew Cab
2009 Palomino Sabre 30RLDS
Reese 16K Fifth Wheel Slider
Yamaha ef2400is
Dave H M
IL
I run 30 hooked up and zero empty.
You will have to check and see what levels your truck up.
AZ T&T
Mesa, AZ
Mine are fairly new. I started at 20lbs and worked may way up. 35lbs feels pretty good.
AZ T&T
2012 Jayco Eagle Super Lite 29.5RKS
2011 Chevy 2500 HD 4x4 Duramax
B&W Companion Hitch - Firestone Ride-Rite Air Bags
Honda EU2000i Generator
danojeno
Corona, CA
50 loaded, 10 unloaded.
2006 Chevy 2500HD 8.1 4x4 CCSB
2012 Eclipse Stellar 28SBG, Spring Over Axle
lawnspecialties
Garner, NC
I run as much as 80-90 psi when the Cyclone is loaded with everything including the 100 gallons of water. Alone, the thing has a pin weight of 3300 lbs. and then we add the water.
Without the water, we run around 50-60 psi.
Unhooked, I leave it at 5 psi. My compressor won't allow it go below 5 psi because I don't want the bags to get pinched if they are empty.
2011 Ford F450 4X4
2011 Cyclone 370C
dubdub07
Colorado Springs
My pin wt. is like yours and I like 25-30.
2012 Montana High Country 333DB
*NEW* 2012 Dodge 3500MEGA 6.7 CTD, 2012 Jeep JK Rubicon, 2012 Durango Citadel, 2010 Harley Heritage Softail....American STEEL = American profits.
glamisorbust
Arizona
I run 50-80 psi fully loaded. About 40-50 psi with the trailer empty, and 5psi with the truck unloaded, as stated in the air lift manual. Can't run them completely empty, the compressor will kick on by itself to bring it back up to 5psi. Love my airbags!!!
