bkd148
Spanaway, WA.
I plan on upgrading my old cathode ray TV's to new digital flat screen TV's. I'm looking for pro's and con's on LCD's and LED's. I am not ever going to need HD so 720p is fine with me and I don't want a plasma. I'm just asking for opinions on one versus the other. Thanks, Marty
2002 Beaver Patriot Thunder
Cat C-12 455hp. 6spd. Allison
2002 Jeep Wrangler Sahara
sch911
Rochester Hills, MI
They are both LCD sets the only difference is the type of backlighting. LED uses allot less power. Picture quality is comparable.
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
PandK
Greenville, SC
I went with LED partly because they were, generally, thinner.
Paul and Karla
Cinnamon & Pequeno - Spoiled Rotten Chihauhuas
2004 Rexhall Rexair DP3955
2013 Chevy Traverse
2oldman
Winchester WA
Perhaps this 5-page thread on the subject will be of help:
LED v LCD in technology.
301TBS
Ontario, Canada
We picked led, it is much lighter, also works on 12volt power as well. picture is great. we have 26" LG.
2012 Crossroads Z1 271B
2009 F150 4x4,4.6,3v. 6spd. 3.73/9.75
Reese dual cam
Old-Biscuit
Across the USA
All LED's are LCD's.....hehehe
LCD televisions have a fluorescent lamp in the back providing the light and LED screens are lit up using hundreds or thousands of tiny light emitting diodes. Each pixel has its own light emitting diode to light it up.
Side lite LED's can be very thin & light weight.
HERE'S an article on the differences etc.
Go to a store that has lots of TV's on display showing same channel......walk up & down them until the right one says "Buy Me"
Go to check out....go home...set it up...sit back and enjoy
We replaced our old 25" analog in 5'vr with a 32" Vizio LED/LCD.
1.75" thick (thin...HA) and 13#
Macktee
Canada
I also changed to a 32" LED up front and a 27" LED in back. Because of the weight and thickness. They mounted very easily. However, the Visio is a great make, while I am not happy with the Dymex 27. Due to the low cost I will probably take the Dymex out and replace it again this year with another Visio. Macktee
04 Monaco Dynasty Diamond 1V ( Homer II)
2012 Ram 1500 4X4 Quad Cab towed
2011 Dodge Journey
2013 Cargo Mate 24ft enclosed car hauler
Tom and DW Nancy
Holliday Trails member
Good Sam Life time member
FMCA member# F419937
s N s
Michigan
As mentioned they are LCD with back lit LED. I'm going for the LED only because it's thinner and a bit lighter.
Steve & Sally
HiTee & Hudson (Our Little Poms)
Houston & Heidi (Forever In Our Hearts and Never Forgotten)
04 NEWMAR MACA 3778 W22
05 pt Cruiser Vert 5 speed
Demco baseplate with Commander Tow Bar
"Never try to outsmart your common sense"
dav5942
Stuart, FL
Went with LEDs due to being brighter(helps when your eyes are gettin old). In addition due to thickness was able to mount one on a wall adjacent to a slide that only had a couple of inches of room. Manufacturer is irrelevent-just compare and pick the picture you like best.
Got a better picture, viewing angle, better blacks and brightness with a new 60" Plasma(no thicker or heavier than a LCD) for the house(first house in 20 years)-would not advise Plasma for coach due to heat. The smaller LED/LCDs have a better picture than the smaller Plasma.
2007 Newmar 42' Mid Engine w/Fatboy,Grizzly 550s-in Garage,Rubicon w/4" lift,MotorMetal whls,MickeyT Baja tires-Cherokee w/4"lift in tow, Hog Valley FL(a diamond in the rough)
2010 Part2
Alaska Fishing Newmar Mid Engine 2010 Sportfishing
rbrand
Victoria, BC, Canada
I just finished putting an oak door on the cupboard that used to house a large heavy TV. I hung a 24" LED LCD TV. on the door. It is much better than the old TV much, much lighter, only 1.5" thick. and I have all that space behind the door for storage.
The less you plan the more options you have.
GMC Sierra HD 2500 Duramax
Jayco Eagle 28l
Ex Navy Diver
Ex Archaeologist
Ex Museologist
Actively retired
