RV.Net Open Roads Forum: ISC cummins goes only 15mph and it stalls
 > ISC cummins goes only 15mph and it stalls
i85rv
Greenville
Posted: 01/05/12 06:33pm Link  |  Print  |  Notify Moderator
ISC cummins in Winnebago Ultimate Advantage goes only 15mph and it stalls will not get faster, has new filter, got plenty of fuel, any suggestions?
AF_Medic
Cabot, Arkansas
Posted: 01/05/12 06:48pm Link  |  Print  |  Notify Moderator
Sounds like it's in limp mode. Anyway you can reset the computer? Might try leaving the battery out for 24 hours and see it that will reset the computer. Any check engine lights on?
Tom/Barb
Oak Harbor, Wa
Posted: 01/05/12 06:49pm Link  |  Print  |  Notify Moderator
Air in the system? or 1 of 2 filters still clogged? ECM needs resetting ?
Air in system.... cycle the key on 3 minutes and off, several times.
1 of 2 filters still clogged, be sure the engine filter is clean along with the chassis filter.
ECM... resetting. remove the Negative lead to the battery, wait 5 minutes, touch it back to the batteries for 1 minute, do this 3 times. reattach to the battery.
My 350 ISC was doing the same thing, doing these three things fixed it, I fought that problem for well over a year before I finally figured it out.
2000 Newmar mountain aire 4081 DP, ISC/350 Allison 6 speed, Wrangler JK toad.
wtasch
Augusta
Posted: 01/05/12 06:51pm Link  |  Print  |  Notify Moderator
does it have both fuel filters replaced? If so, I know of a problem a freind had with a 350 hp isc. His went slow when it goes into limp mode. it turned out to be an accumulator pump on the injector pump. But for starters make sure you fuel lift pump is working by having someone turn the key to the run position like you're going to start it. You should here your lift pump turn on for 30 seconds before you start. If not sound, there is a fuel for that pump you can check. good luck. Bill
wtasch
Augusta
Posted: 01/05/12 06:54pm Link  |  Print  |  Notify Moderator
meant to say there is a fuse for the lift pump you can check
pulsar
Lewisville, NC
Posted: 01/05/12 07:02pm Link  |  Print  |  Notify Moderator
Moved from Forum Technical Support.
RogerComm
West Columbia, South Carolina
Posted: 01/06/12 06:19am Link  |  Print  |  Notify Moderator
I also have the ISC and experienced the same thing going up the entrance ramp to I-10. After pulling off to the side, I lifted the engine cover in the bedroom and immediatley saw the exhaust brake was completely engaged, I was able to get it pushed back off and left it turned off until I could clean and lube the cylinder.
Roger & Denae
W4OHX
FMCA 334124
2004 Monaco Camelot 40PST
Lexus LX-470 Toad
Blue Ox/Brake Buddy
squeakkos
parker az
Posted: 01/06/12 07:33am Link  |  Print  |  Notify Moderator
have you changed the air filter?
John & Angela
World Travelers.
Posted: 01/06/12 08:23am Link  |  Print  |  Notify Moderator
If you are not getting an engine light my guess is your lift pump is either packing it in or the fuel lines to and from the lift pump are breaking down.
Let me guess.
* It starts and idles fine.
* Has no power under load
We went through two lift pumps before we figured out the lift pump hoses were breaking down. These are the hoses between the rear bulk head near the rear axle and the lift pump. Maybe 8 to 12 feet.
Do you have one or two filters.
By the way it took Angela a couple hours or so to change out a lift pump. Mostly done through the whole in the bedroom floor.
You don't mention what year your coach is. I am willing to bet it is a 2003 ish.
Lift pumps are not expensive. A few hundred bucks. We keep a spare in the spares box.
2003 Revolution 40C Class A. Electric smart car as a Toad on a smart car trailer
Life is not measured by the number of breaths we take but rather by the moments that take our breath away.
wny_pat
Western NYS
Posted: 01/06/12 09:34am Link  |  Print  |  Notify Moderator
And please come back and let us know what it was!!! You've been given good troubleshooting advice.
“All journeys have secret destinations of which the traveler is unaware.”
