RV.Net Open Roads Forum: Class A Motorhomes: throttle return springs
 > throttle return springs
Berjmobile
El Cajon, CA
Posted: 01/07/12 10:50pm Link  |  Print  |  Notify Moderator
My 8.3 Cummins mechanical diesel is now 20 years old. I am finding that on occasion the engine RPM is a little to high when going from a drive position to reverse. I have to go back to the rear and lift the bed to manually pull the throttle back to slow the engine down. With that done, the the Allison will shift. So far, it has happened twice. The Cummins dealer advises that the spring set is now obsolete and are no longer available. Any suggestions from the Forum members? Any help will be appreciated.
Executive
Posted: 01/08/12 02:01am Link  |  Print  |  Notify Moderator
I ran into a similar situation with my 96 Dynasty. There is an adjustment that can be made to the throttle assembly to shorten that spring. I played around with it and it was satisfactory for a time, but I ended up simply getting a new spring from my local NAPA store....after installation, you will have to adjust it to get it to perform to your satisfaction. I made some minor adjustments until I got it to where I felt it was perfect......Dennis
Dennis and Debi
Chevy HHR W/ ReadyBrute
Fourth Year Full Timing Click here to view our travel blog
SCOMP225
Brownsburg,Indiana
Posted: 01/08/12 06:55am Link  |  Print  |  Notify Moderator
I too replaced my Throttle return spings last year, I also adjusted the pedal "Morse" cable to take some slack out of it. These things just have normal wear for the age.
* This post was edited 01/08/12 07:55am by SCOMP225 *
Chuck
1992 American Eagle
eHoefler
ozark mountains
Posted: 01/08/12 07:06am Link  |  Print  |  Notify Moderator
The throttle shaft and bushing could have excessive wear, causing it to bind up. A stiffer return spring will bandaid it for a while, but the stronger spring will cause it to wear faster, eventually leak, and possibly cause the throttle to stick at a high rpm or jam up and not move at all.
2010 Ram 3500, Crew Cab, Long bed, 4 x 4,Dually, Lights & Siren!
2006 40' Landmark Mt. Rushmore
just me
Salt Lake City Utah USA
Posted: 01/08/12 07:12am Link  |  Print  |  Notify Moderator
Just put a double spring on it, our 5.9s came this way and yours probably did to when new. A squirt of lube mite help also.
Is your MH drive by wire?
95 Dodge CC #5 TST plate Flame Red/Silver
not totaly stock
2007 fiver
Tag Ma-haul has been suggested for a name but now The Shoe box
pashir
Buchanan Dam, TX
Posted: 01/08/12 11:26am Link  |  Print  |  Notify Moderator
Be careful. Too much spring tension can cause the wind-up spool in the cruise control to strip.
jtfcons
Washington State (The dry side)
Posted: 01/09/12 04:25pm Link  |  Print  |  Notify Moderator
I replaced that spring along with the TPS bracket a couple of years back. Got both from RVChassisParts.com
The spring was cheap, but the bracket not.
Also, the tension of that spring was pretty sensitive. There are multiple positions that the spring can be placed, and I had to fiddle with it to get the right peddle/treadle feel.
John & Sharon, 2 Daughters, 2 Sons-in-law, 5 GK
Scottish Terrier (Chloe)
1997 HR Imp., 38CDS, 1 Slide
325 Cummins C8.3Mech., MD3060, EBw/Coast.Sw.,
Toad-98Tracker 4X4 or 03GMC Envoy 4X4, Excallibar TB, Pressure Pro TPMS, Henderson Mot. Ctrl. Units
Cat320
Somewhere in the USA
Posted: 01/09/12 07:54pm Link  |  Print  |  Notify Moderator
Just helped a friend replace the spring on his 8.3, got them at an auto part store. Had one in the front with the accelerator and one in the back adjusting the spring base on how it "felt" to the guy in the front.
