RV.Net Open Roads Forum: Class A Motorhomes: Glass Shower Doors
 > Glass Shower Doors
TexasH
Katy, TX
Posted: 01/08/12 05:20pm Link  |  Print  |  Notify Moderator
I'm thinking about replacing the stained accordion fold shower door in our tub with these sliding glass doors. Has anyone had any experience with this. DW says we have to do something with the old accordion doors - either replace them with another accordion door or something like this.
2002 Southwind 37U Ford F53 - V10
2007 Jeep Liberty Toad
JimGo
Hawaii
Posted: 01/08/12 05:45pm Link  |  Print  |  Notify Moderator
Should work. Do the glass doors have something to lock them in place while in motion?
sowego
northwestern corner of the Nebraska panhandle
Posted: 01/08/12 05:53pm Link  |  Print  |  Notify Moderator
A glass/window/door store can custom cut a glass door enclosure. However since water all over the country will keep you working hard to keep the glass clean from hard water deposits and soap scum--the best choice is a good microfiber shower curtain on a rod. They dry very quickly and can easily be laundered to keep them fresh. You will seldom see a microfiber shower curtain mold because they do dry so quickly even in the confined space of a motorhome.
2002 Tiffin Phaeton
2005 Malibu Maxx toad
PackerBacker
Montreal (Qc) Adirondacks (NY) Myrtle Beach (SC)
Posted: 01/08/12 06:45pm Link  |  Print  |  Notify Moderator
We have them and the only issue is that your rv needs to be really level otherwise they will slide one way or the other when in use. As mentioned you need to have them tied down while rolling.
Eric
2014 Enterra 314RES (Cruiser RV) TT, Equal-i-zer 12K, Honda 2000 Genny
2014 Ram 1500 Quad Short Bed, 5.7L Hemi, 8 speed auto, 4x4, Line-X
FQCC/Camping Quebec, KOA, Good Sam
Davehrn
Ohio
Posted: 01/08/12 06:51pm Link  |  Print  |  Notify Moderator
The shower doors in my class a pop loose from the OEM clip and jump their rails... a spring project will be fixing this. Currently its being held by 2 bungy cords... looked at RV show... no good solutions being used...
~dave
2010 Coachmen Mirada 32ds
DW: Nora
DD: Silas White German Shepherd / Husky Mix
old guy
Oregon (pronounced Or e gun)
Posted: 01/08/12 08:02pm Link  |  Print  |  Notify Moderator
one thing about glass doors is the soap shows up on them more than the accordion doors. Just be sure to caulk all the way around the sides and bottom or you will have a lot of water on the floor to mop up
glodal134
OHIO
Posted: 01/11/12 07:31pm Link  |  Print  |  Notify Moderator
We dry our shower after every use including the glass doors. This helps prevent soap build up and film on nthe doors.
othertonka
Stockton, CA
Posted: 01/08/12 10:46pm Link  |  Print  |  Notify Moderator
My 2004 Southwind 32V came with those triple glass panel shower doors and they have an elastic band type of restrainer that is fastened to the wall and hooks over the towel bar to keep the doors in the open position for travel. No problems in 7 years
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
ronfisherman
SE Michigan
Posted: 01/09/12 05:08am Link  |  Print  |  Notify Moderator
Installed the same doors in our MH last fall. They work well. One wall was not square to door frame. Had to make a angled spacer to fill in gap. Made a nylon strap that snaps in place to hold shower door while traveling. The provided clip does not hold doors in place good enough while traveling. We drove 2000 miles since Christmas with no problems.
We use Scrubbing Bubbles to keep shower doors and shower clean in the MH and home.
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad
Super C Group Forum
Clay L
Palisade CO
Posted: 01/09/12 11:03am Link  |  Print  |  Notify Moderator
Regarding soap scum. Some folks use a squeegee to remove water from the glass and walls after a shower. Our surround has some embossed areas so a squeegee won't work very well. Instead we use a yellow fiber chamois - like the Shamwow advertized on TV. It works great.
By the way we have been using the fiber chamois for years before the dork with the Kewpie doll haircut started advertizing them as Shamwows.
I pay as little as $1 for the same thing.
Clay (WA5NMR), Lee (Wife), Katie & Kelli (cats) Salli (dog).
Fixed domicile after 1 year of snowbirding and eleven years Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
