RV.Net Open Roads Forum: Jake brake not working on 5.9 07 Dodge
Search only in Tow Vehicles
 > Jake brake not working on 5.9 07 Dodge
reddwar
Valley Center Ks. /Now Scotland SD.
Posted: 01/11/12 11:04am Link  |  Print  |  Notify Moderator
Took our 5.9 07 3500 Dodge over for an oil change a few weeks back. They said that the rear seal was leaking it has a little over 90K on it so Dodge is paid for it. We were heading south on the 27th so on the 26 stopped by my mother to say bye. Well there was oil on her drive way. So called Dodge dealer up & he could not get me in untill the 29th so I said ok as I wanted it done before we left. We did not get it out untill the 6th we hooked up & took off. Well we got to NM going down a hill pulled the jake out - nothing!
To the best of my knowledge the jake brake was working when we took it in. Is there any thing they could have left lose while removing & replacing the pan, oil pump gasket & any thing else that would leak?
Also I now have a little oil on the intake manifold, that we never had before, it looks to be comming from around the power steering pump but the vaccum pump for the Jake brake is just above the power steering pump. We are in Quartzsite & there is not a car wash in town that I have found but we are going to Blythe this afternoon so will clean oil off then.
red
ScottG
Bothell Wa.
Posted: 01/11/12 11:13am Link  |  Print  |  Notify Moderator
I'm wondering if they had to disconnect the vacuum line from the pump to gain clearance or something. Can you hear the pump engage?
Scott, Grace and Wesly
H0NDA eu2000i
donn0128
Pronounced Ore-gun
Posted: 01/11/12 11:20am Link  |  Print  |  Notify Moderator
I assume this is an exhaust brake you added? Because the 5.9L never came with one from the factory. So I guess you will have to do some trouble shooting. Is it vacuum or electric operated?
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
reddwar
Posted: 01/11/12 11:26am Link  |  Print  |  Notify Moderator
When setting still & pull the jake out I would get that low sound. Not there now. No change at all when I pull it out.
red
reddwar
Posted: 01/11/12 11:33am Link  |  Print  |  Notify Moderator
Jake is the authorized exhaust brake for Dodge covered by Dodge warranty so when I bought the truck I said I wanted the Jake barke. So Dodge put it on before I picked up the truck.
As I said it has a vaccum pump. But I do not hear a leak at the pump, or at the brake, but I do not have the best hearing.
red
ScottG
Bothell Wa.
Posted: 01/11/12 01:15pm Link  |  Print  |  Notify Moderator
What ever you do, don't leave the pump engaged (dash switch on) if it isn't working because if there's a leak the pump will burn out quickly.
hawkeye-08
Northwest
Posted: 01/11/12 05:49pm Link  |  Print  |  Notify Moderator
I got the impression that the dealer is many miles back home, not in Arizona for winter...
Check fuses if there are any for that.
HappyKayakers
Black River Falls WI
Posted: 01/11/12 01:53pm Link  |  Print  |  Notify Moderator
I have an '06 Dodge with MOPAR Jacobs exhaust brake added after purchase. Can't help you with your current problem but if it's more than just a disconnected line, check out the nearest Cummins dealer for replacement parts. They're the exact same parts, just much cheaper through Cummins instead of Dodge. I had to replace the vacuum pump on mine and saved almost $800.
Joe and Dakota, the wacko cat
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2006 Heartland Bighorn 3600RL, MorRyde suspension, TrailAir pinbox
http://happykayakers.com/blogger/
45Ricochet
North Idaho
Posted: 01/11/12 02:04pm Link  |  Print  |  Notify Moderator
Actually 2006 was the 1st year it was a option with the 48RE which was installed by the Dodge dealers.
Does the red light on the switch light up? Sounds like a electric wire is disconnected, maybe tech missed re attaching it. If not check the vacuum line.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
Al B
Cowtown
Posted: 01/11/12 05:36pm Link  |  Print  |  Notify Moderator
Run it back to the dealer that did the work on the seal, state that it worked before and see what they say, you got nothing to lose. If it is a failure, then they will show you the problem
Cummins Powered
