RV.Net Open Roads Forum: Class A Motorhomes: RMP3 failure
 > RMP3 failure
kenj1
Benbrook,Texas
Posted: 01/13/12 07:49am Link  |  Print  |  Notify Moderator
When I did the rear cap, I did not wash after bar keeper(I think and @ at 76 years it is vague sometimes).
On the rest of the coach I washed 2 times after barkeeper and maybe this is the key.
Thanks again: Ken
Alpenliter
Fulltimer: Wherever we are!
Posted: 01/13/12 08:38am Link  |  Print  |  Notify Moderator
Thanks again: Ken
Bingo!
My first Wife Linda, 45+years
2004 F-450 CC, DRW 6.0 Classy Chassis Upgrade
Bulletproof Diesel upgrades
1997 33' Alpenlite
400 Watts Solar
Lifetime Good Sam Member #39644174
Escapees SKP#89882
Vietnam Vet '67-'68
Extreme Makeover RV Style!
fcooper
Richmond Hill, Georgia
Posted: 01/13/12 08:26pm Link  |  Print  |  Notify Moderator
Alpenliter wrote:
Now for the easy part. Pour some Red Max Pro (RMP) into a shallow container (a pie pan works well). Fold a microfiber rag to about hand-sized, dip into the RMP (trust me, use gloves!), and squeeze out the excess. How much/how wet? You want it more than damp, but less than dripping. Now simply wipe down the surface of the motorhome with the wet rag.
I did part of my motorhome with this method, but found that placing the Red Max Pro in a spray bottle, and spraying the liquid onto the microfiber helped me control runs and eliminated air bubbles. You can control the wetness of the microfiber pad without squeezing out the excess. The round microfiber pads sold for applying car polish work great for this also.
Fred
Fred & Vicki
Richmond Hill, Ga
2000 Holiday Rambler Endeavor/Freightliner/330 Cat
2000 Honda Odyssey toad w SMI Silent Partner braking system
Tire Sentry monitoring system
Alpenliter
Posted: 01/13/12 09:22pm Link  |  Print  |  Notify Moderator
Fred
I couldn't find a good microfiber rag (supposed to be white) so I went to the paint dept and bought some staining pads. They worked well too. I like the spray bottle idea!
D.E.Bishop
Eagle Rock, CA
Posted: 02/09/12 12:22pm Link  |  Print  |  Notify Moderator
I'll add my $0.37 worth(adjusted for inflation and retirement income), I did our MoHo last September and after reading the posts here decided to wash first with car wash soap, thenscrub with BKF, them wash with plain water then with Car wash soap and then with plain water. I used terrycloth bar towels for all the washing. I applied the RMP3 with a series of blue microfiber towels on everything but the windows and glass headlights. Thought I was careful about runs, I wasn't but it's okay I can live with them. Our rig has been outside exposed to the elements for 22 years and was sunburned and the decals cracked and faded. The filon finish is good, not original but I didn't expect it would be. The fiberglass radius of the rear cap had fibers exposed and they are now covered, the radius of the front cap is hard to get to and I didn't get as good a finish as on other parts. Due to the sun damage it takes a lot more RMP3 to make our surfaces shine.
We did a ten week, thirteen thousand mile trip across the country and back, lots of bugs in the plains states, snow in PA and rain all over Canada and the east and a mechanic who cleaned the front end with something very strong and greatly damaged the shine. Washing the rig with carwash soap and applying a few coats to the area the mechanic clened has restored the luster and the front end looks even better than when we left.
Other than preparation work, the big thing is try to apply the RMP3 when the surface is cool and out of the sun. I feel that it dries slower and gives a better shine but it still looked good where I did do it in the sun.
Lots of elbow grease when using the BKF, easy applying the RPM amd so far a durable finish.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
1990 Bounder 27D
1995 Suzuki Sidekick 4X4
Stowmaster 5000
big white whale
Edmonton--AB Canada
Posted: 02/10/12 10:28am Link  |  Print  |  Notify Moderator
Hi; I applied red max on my sightseer about a year ago now and mine sits outside with no cover in the winter. Our weather here is freezing for 5 months of the year and I have had no fading, cracking, peeling, or yellowing and the mh is white. Could be your prep left some powder or ? on the cap, it should not lift off and the shine should be the same as when applied.
Super Guy 78
Augusta, GA
Posted: 02/14/12 01:27pm Link  |  Print  |  Notify Moderator
Somebody said you can not buy it at Lowes anymore, Just got back form Lowes, and brought another gal, they had 20 gals still in stock, and said they would still have it in stock if we keep buying.
Super Guy 78
Augusta, GA
Posted: 02/14/12 01:28pm Link  |  Print  |  Notify Moderator
Sorry mean to say (CAN'T)
 > RMP3 failure
