Our Place
Southwest Ohio
My camper has a Dometic digital thermostat for the furnace and air but its a confusing little thing. Would it be possible to use a residential thermostat or are the voltages wrong? Is there a "better" RV digital thermostat?? Mine don't show inside temp, just the setting its on and it runs the AC fan with the furnace on, but not the AC compressor. I guess thats for better air circulation?
2001 GMC 2500HD 4x4 with 8.1 gas Allison trans
2011 Coachman Chaparral 268RLE "Campy"
tenbear
Northern Vermont, USA
Take a look at this.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
Bill/Diana
Southeastern Pennsylvania
Click here to see a great detailed document on how to install a Hunter residential thermostat. I followed these directions just a few months ago and it is one of the best modifications I made to the motorhome. Follow the directions and you cannot go wrong.
Hope this helps.
Bill & Diana
Please click here to visit our Website
John3872
Iowa
tenbear wrote: Take a look at this.
X2
This outlines exactly what you need to. I installed residential programmable in my last two campers.
2003 Chevy 2500HD Duramax Crew Cab
2009 Palomino Sabre 30RLDS
Reese 16K Fifth Wheel Slider
Yamaha ef2400is
Kirk
Livingston, Texas.
Quote: ......... it runs the AC fan with the furnace on, but not the AC compressor. I guess thats for better air circulation?
May I ask why you would want to operate the a/c compressor with the furnace on? The fan is that way to give you the option of using it to move the air about inside of the RV, when not using either the a/c or the furnace. I suppose that you might want it when heating, but I have only run mine if neither heating nor cooling.
Good travelin! ........Kirk
Professional Volunteer
Fulltimer for 11 years,
URL: www.adventure.1tree.net
ScottG
Bothell Wa.
The Hunter t-stat is a good improvement but if you wan't something that keeps the temp right on target without any overshoot, and runs the furnace less overall, get one that's Energy Star rated.
Scott, Grace and Wesly
H0NDA eu2000i
Kiwi_too
Western, WA
John3872 wrote: tenbear wrote: Take a look at this.
X2
x3
Very easy.
May God bless your travels
Me, The Wonderful Wife
and two Spastic Border Collies
U.S. Army Retired
2004 Coachmen Aurora, 3480DS
2007 Saturn Outlook, FROG
sc3283
St Louis
Our place is yours a CCC 4 button or 5 button version? If so you can not use a residential T stat
04 D-Max Crew Dually
96 Monaco Dynasty 36'
dougrainer
Carrolton, Texas
Our Place wrote: My camper has a Dometic digital thermostat for the furnace and air but its a confusing little thing. Would it be possible to use a residential thermostat or are the voltages wrong? Is there a "better" RV digital thermostat?? Mine don't show inside temp, just the setting its on and it runs the AC fan with the furnace on, but not the AC compressor. I guess thats for better air circulation?
The AC fan on FURNACE mode will only work if you have the tstat on lo/med/hi fan. If you put it on AUTO fan, the AC fan will not run on furnace. And yes, the AC fan on furnace is designed for better hot air circulation. Doug
dougrainer
Carrolton, Texas
Bill/Diana wrote: Click here to see a great detailed document on how to install a Hunter residential thermostat. I followed these directions just a few months ago and it is one of the best modifications I made to the motorhome. Follow the directions and you cannot go wrong.
Hope this helps.
The tstat he has, has only 3 wires to the tstat. Will ANY aftermarket tstat work with only 3 control wires????? Doug
