jolooote
Miami, FL
My 2006, Class'A' on the Ford F53, V10 w/5 Speed Tranny uses ONLY 'MotorCraft Mercon 'SP' tranny fluid, according to the manual. Its not available in regular Auto parts stores. I must order & go get it from a Ford dealer 20 miles away.
Is there a substitute fluid thats available at most Auto parts stores?
Joe&Charlotte, Nat'l SurfSide DE34D Ford 362HP 5speed
Rusty, Rosie, Snuffy Dogs
Leroy's a Conure
If a 'Little' is good, 'Alot' ain't better.
cpmath
New York
Duh, you already said it's not available in local auto parts stores so I think you already answered your own question.
LVJ58
Las Vegas, Nevada
Disregard my post on that Mercon V, Home Skillet's correct it can't be used where SP is specified---I read it wrong-
sorry about that....
edited 01/12/12 07:51pm by LVJ58 *
Jim & Sherry Seward
Las Vegas, NV
2000 Residency 3790 V-10 w/tags & Banks System
2003 Suzuki XL/7 toad
Home Skillet
Pearland Texas
O'Riley's has the Mercon SP fluid.
If you drain the fluid at the drain plug, you will need 8 qts to refill the trans.
edited 01/12/12 07:54pm by Home Skillet *
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,SmarTire,Bilstein Shocks,Trans temp guage,Lowrace iWAY
jolooote
Miami, FL
O'Riley's ? I'm in S.Florida.
BobJoh
Whitestown, IN 46075
The clerk will know the new spec, Merc V or VI
BobJoh
Home Skillet
Pearland Texas
jerseyjim wrote: EIGHT quarts? My manual specifies 17.7 Yeah....8 quarts at the drain plug...but what about the remaining 9.7?
What is the advantage of swapping out 8 quarts and leaving the rest in? Go to a garage and have them ump out the old and pump in the new. (Special machine just for that)
Better than not doing it. No?
You can drain 8qts, drive around the block and drain the fluid again. Then refill.
I was a Ford tech for 25 years and in the past five years, I have seen many trans failures due to improper trans flushing done by inexperienced mechanics.
Pirate
Appalachia
ech tips
Approval to Service ALL 5R110 Automatic Transmissions with MERCON® LV
Beginning immediately ALL (2003 to 2010 MY) 5R110 automatic transmissions can be serviced with MERCON® LV automatic transmission fluid in place of MERCON® SP.
Initially only the 2009/10MY 5R110 automatic transmissions were filled and serviced with MERCON® LV. In an effort to reduce complexity, Ford Motor Company is allowing all previous model year 5R110 automatic transmissions to be serviced with MERCON® LV automatic transmission fluid. This pertains to top off as well as fluid replacement. Mixing of MERCON® LV and MERCON® SP in the 5R110 transmission is acceptable. Extensive testing has been performed to insure there are no functional or durability concerns with the use of MERCON® LV in the 5R110 automatic transmission.
Vehicles affected are F-Series Super Duty trucks (including chassis cab, motorhome, LCF).
Motorcraft MERCON® LV is now available in three sizes:
Part Number: XT-10-QLVC - 1 quart
Part Number: XT-10-DLV - 55 gallon drum
Part Number: XT-10-BLV - Bulk
Note - I could locate an "official" Ford type document where that came from.
Search my posts for a good external filter replacement too.
edited 01/13/12 05:27pm by Pirate *
W4RLR
Sewanee, Tennessee
And to really muddy up the waters, the spec now calls for MERCON LV, the latest and greatest Ford transmission fluid.
Richard L. Ray
SSgt USAF (Retired) Life Member DAV
W4RLR 146.52 mhz
2005 Ford F-250 Lariat Crew Cab
1995 Jayco Eagle 277RBSS fifth-wheel
"Never ask a man what kind of computer he drives. If it's a Mac, he'll tell you. If not, why embarrass him?" Tom Clancy
jerseyjim
New Jersey
