RV.Net Open Roads Forum: Fifth-Wheels: 2010 Cougar 276RLS waterpump location
 > 2010 Cougar 276RLS waterpump location
ICDUCKS
Western New York
Posted: 01/13/12 06:03pm Link  |  Print  |  Notify Moderator
My water pump has quit working and I cant seem to find it. Any help would be appreciated.
skylos
Columbus, OH
Posted: 01/13/12 06:18pm Link  |  Print  |  Notify Moderator
In my first rv, it was under the bathroom sink.
In my second rv, it was under a drawer in the kitchen.
So look in odd places like that. Take a drawer out and see whats beneath. You'll probably find what you're looking for it.
trike2
idaho
Posted: 01/13/12 09:49pm Link  |  Print  |  Notify Moderator
It's like a hide and seek thing with the manufacture. I found mine in the basement, behind a panel that was used to hide the pump and furnace unit. These were located behind the exhaust of the furnace and water fill tank access door on the left side of my fifth wheel. It was easy to remove and replace.
2005 gmc 3/4 hd, sb, 4x4, 8.1 gas/allison 17,000 and climbing.
2005 Lakota, by Monaco, 3 slds, 29f.
FlashG
Salem, Oregon
Posted: 01/13/12 10:23pm Link  |  Print  |  Notify Moderator
Try under the kitchen sink - that is where the pump was in our 276 Cougar.
2012 Ford F350 Lariat Diesel Crew 4X4
Monaco Knight 38pst
ReverendCharles
on the road
Posted: 01/14/12 12:08am Link  |  Print  |  Notify Moderator
In the cabinet to the right of the entrance door unless they moved them.
pbar34
Altadena, CA
Posted: 01/14/12 12:10am Link  |  Print  |  Notify Moderator
Under the stove, behind the electrical panel on my '05. I had to cut an access panel under the sink (into the under stove area) to easily access mine when I replaced it. It looks like they designed it so that you have to remove the entire electrical panel, converter, unhook wires, etc. to get access to the pump on my unit. Pretty lame. My access panel under the sink is held in place with velcro straps now.
Good luck,
Phil B.
2005 Cougar 275EFS
2001 Chevy CC, D/A
Dave H M
IL
Posted: 01/14/12 06:31am Link  |  Print  |  Notify Moderator
if you got big removable panel on the rear of the basemebnt, that would be the place to look first for me.
however why not call a RV place and get the skinny for your particuar model?
jodeb720
Los Angeles
Posted: 01/14/12 11:25am Link  |  Print  |  Notify Moderator
I have a 2010 244rls. my water pump is in the back corner (drivers side back corner) below the cabinet. There are four square drive screws you remove to access the water pump. Ironically, it's behind where the 120volt connection is so I have to pull out all the electrical wire to access the pump.
Good luck!
jbutcher3
Springfield,oh
Posted: 01/14/12 06:55am Link  |  Print  |  Notify Moderator
Look under the counter, pull out both drawers at the entrance door us should find the pump to the right behind a affixed panel, by the way being very flexible will help, while you are there put in a quite kit or up grade to a more quite pump, it really help the noise level on our unit. no special tools required for the replacement.
good luck
Jim
cpaulsen
California
Posted: 01/14/12 03:15am Link  |  Print  |  Notify Moderator
Check the little cabinet just to the left of the entrance door....should be 4 screws holding the panel to the cabinet.
cpaulsen
