RV.Net Open Roads Forum: Tech Issues: Adding A Portable Solar Panel
 > Adding A Portable Solar Panel
BMCM
Santa Clarita, CA
Posted: 01/14/12 10:42pm Link  |  Print  |  Notify Moderator
Have a volt meter.. should have a sunny day tomorrow.
rw
F-350, Scorpion, QC, Dually/Alpenleak
All Gave Some,
Some Gave All.
Almot
Vancouver BC
Posted: 01/15/12 12:33pm Link  |  Print  |  Notify Moderator
I like the idea of 2 panels in parallel via one controller. With 2 assumptions that I'm 99% positive of - that both controllers are PWM and installed 100W panel has working voltage 17 or 20 - minor difference in working voltages won't matter for one controller. His portable 50W panel comes with a huge 21A controller, so it will be able to handle both panels.
BMCM
Santa Clarita, CA
Posted: 01/15/12 03:00pm Link  |  Print  |  Notify Moderator
Couldn't see any specs on the back of my panel.
My panel measured 20v at the the connection from the panel, the 50w panel measured 20.8v.
rw
pianotuna
Regina, SK, Canada
Posted: 01/15/12 06:03pm Link  |  Print  |  Notify Moderator
Hi,
That is as close as you are likely to find. You could in theory introduce voltage drop on the 50 watt panel to reduce the difference.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
BFL13
Victoria, BC
Posted: 01/15/12 05:50pm Link  |  Print  |  Notify Moderator
They are close enough to use together, both being "12v" panels that are approx 17v with 20/21v open circuit. You can clamp the one controller to the battery bank while the installed one is still connected and they will add their amps.
After the batteries are mostly charged up, one controller may stop adding because its high voltage set-point might be a little less than the other's, but by then the batteries will be accepting few amps and the one controller still going can do it all anyway.
Try it out. It won't break anything. You will need an ammeter to see the "action" as it develops.
2003 Chev 2500HD Gas, 2003 Komfort 26FS 5er
See Profile for Equipment List
BMCM
Santa Clarita, CA
Posted: 01/15/12 08:31pm Link  |  Print  |  Notify Moderator
Heading out for a week or so of boon docking.. the extra 50 watt panel should help.
Thanks to all for your input..
rw
2oldman
Soap Lake WA
Posted: 01/15/12 08:34pm Link  |  Print  |  Notify Moderator
a little.. don't expect much.
BMCM
Santa Clarita, CA
Posted: 01/16/12 10:17pm Link  |  Print  |  Notify Moderator
never do.....
