RV.Net Open Roads Forum: Tech Issues: ChargeWizard Extension Cord
 > ChargeWizard Extension Cord
RJsfishin
Winston Or.
Posted: 01/14/12 06:22am Link  |  Print  |  Notify Moderator
Anyone know of an extension cord for Charge Wizard ?
Otherwise extending it 5ft w/.....same size wire be any problem ?
Thanks
Rich
'01 31 ft Rexall Vision, Generac 5.5k, 9245 conv, 400 watt inv, 2 12v batts, ammeters, KingDome/sat, Two Oly Cat heaters, and towing a '05 Jeep Liberty, or sometimes towing a Lowe bass boat.
just me
Salt Lake City Utah USA
Posted: 01/14/12 07:00am Link  |  Print  |  Notify Moderator
seems I read on the web site about how to do that.
95 Dodge CC #5 TST plate Flame Red/Silver
not totaly stock
2007 fiver
Tag Ma-haul has been suggested for a name but now The Shoe box
pianotuna
Regina, SK, Canada
Posted: 01/14/12 11:00am Link  |  Print  |  Notify Moderator
Hi Learjet,
I have the 9100 style of wizard. It does not appear to look like the extension cable in your link.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
ktmrfs
Portland, Oregon
Posted: 01/14/12 09:42am Link  |  Print  |  Notify Moderator
Thanks
use some phone extension cord wire. In the ones I've seen you CANNOT use a phone jack adapter, the end on the charge wizard isn't the standard phone cord jack, it is the end for the cord between the phone and handset, not phone and wall. Don't recall the RJ#. When I needed a longer one, I just got a 25' piece of phone cord, opened the wizard, unsoldered the wires, soldered in the new cord and then crimped on the correct RJ connector. If you don't have access to a crimper and correct RJ connector, just splice phone cord into the existing cord. My charge wizard cord is 25' long going between the converter in the pass through to the utility cabinet in the dining area. Works fine.
2011 Keystone Outback 295RE
2004.5 Silverado 4x4 CC/SB Duramax/Allison
ve7prt
Ucluelet, BC, Canada
Posted: 01/14/12 09:43am Link  |  Print  |  Notify Moderator
Thanks
Extending it is no problem. I did that on one of mine without issue. All you need is your choice of length of 3-conductor cable, and when inserting it into the CW's cable, make sure you keep the color coding correct.
I did the CW on my emergency battery system at home, inserting almost 10ft of cable into the CW's cable. I ended up emailing PD on this issue, and they told me it would be no problem, just make sure that each wire in the original cable stays connected together via the inserted cable (ie - red to red, black to black, etc), and that a cross-connection would damage the CW.
So, fire up your soldering gun, and have at her. Works like a charm!
Cheers!
Mike
Mike Shepherd (CB: The Sheepster / Ham: VE7PRT)
Pulling Power: 2008 Dodge Ram 3500 Quad Cab 4x4 6.7L CTD, 68rfe, Brakesmart, Edge Insight CTS
Sleeping Space: 2007 Rockwood Cargo-cum-Camper Trailer
Mike & Bernie's Website
Learjet
Louisiana
Posted: 01/14/12 10:24am Link  |  Print  |  Notify Moderator
battery tenders and battery minders use the same connections see bottom of page here or here is an extension cord link
* This post was edited 01/14/12 10:31am by Learjet *
2013 Ford F250 XLT 2wd Crew Cab 6.2 and 3.73 rear
2006 KZ Frontier 2303P-F
Dual 6 volt GC batts
Equal-i-zer
Yamaha EF2600c Tri-Fuel Gen.
Champion Model 46595- 3000/3500
sold* 2001 Hurricane 30Q Chevy workhorse
sold* 2006 Nissan Titan CC with tow package
pianotuna
Regina, SK, Canada
Posted: 01/14/12 05:22pm Link  |  Print  |  Notify Moderator
Hi renoman,
Good point. I originally suggested that the wire simply be cut and a commercial telephone cord be used...but I withdrew the post when the next poster said that telephone cord was NG (which I interpreted as no good).
Learjet
Louisiana
Posted: 01/14/12 11:52am Link  |  Print  |  Notify Moderator
pianotuna wrote:
Hi Learjet,
I have the Batteryminder model Model:12117, so that is what I was thinking of.
pianotuna
Regina, SK, Canada
Posted: 01/14/12 02:41pm Link  |  Print  |  Notify Moderator
Hi,
The phone jack is an rj-11
renoman69
Edmonton Alberta
Posted: 01/14/12 03:00pm Link  |  Print  |  Notify Moderator
RJ11 cords come in "crossover" or "straight through" types. Make sure you know what type you need.
2009 Jayco Eagle Superlite 25.5RKS
2008 Silverado 2500HD Z71 4x4 Duramax/Allison
Reese 15K slider
Honda EU2000I,
270 watts of Kyocera solar
Blue Sky 3024i MPPT controller
450 AHs of Trojan power
Iota DLS-75/IQ4 converter
