RV.Net Open Roads Forum: Technology Corner: my cat puked on my keyboard.......
 > my cat puked on my keyboard.......
wolfcat1
Vidor, Tx.
Posted: 01/15/12 09:02pm Link  |  Print  |  Notify Moderator
.......and now some of my keys stick ...so if you see a typo on one of my post blame Sapphire
Wonder which forum this one will get moved to ?
wolfie
ReverendCharles
on the road
Posted: 01/15/12 09:14pm Link  |  Print  |  Notify Moderator
You can unplug it, rinse it out with water and dry it with a fan for a few days. Do not plug it in until it is dry.
Chuck&Gail
In the Colorado Mountains
Posted: 01/15/12 09:28pm Link  |  Print  |  Notify Moderator
Cat was likely after your mouse!
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
wolfcat1
Vidor, Tx.
Posted: 01/15/12 09:39pm Link  |  Print  |  Notify Moderator
Chuck, that was awesome !! Never thought about that
Thunder Mountain
Buena Vista, Colorado
Posted: 01/15/12 09:44pm Link  |  Print  |  Notify Moderator
Yuck! Not much worse than spilling my Jack Daniels and Coke on the keyboard. I've tried the below with good results when I did IT support for my employer. You wouldn't believe what is behind the keys on your keyboard cat puke or not.
BEFORE ATTEMPTING BELOW REMOVE THE BATTERY AND UNPLUG THE COMPUTER.
Since the computer is still working, it tells me the "liquid" did not get through the membrane behind the keyboard.
If the keys don't start sticking, ignore it. After a few days, you could blow out the keyboard using canned air or compressor on low pressure. Remember that if it isn't broke don't break it.
If you have sticking keys, keep working the involved keys while blowing out the keyboard with canned air or compressor on low pressure.
If above does not work, and keys continue to stick, you can pop the key tops off using a small screwdriver or some type of small flat blade. Just be gentle.
Scrap the puke loose with some type of tool. Then blow out the dry residue with canned air or compressor on very low pressure.
If there are a large number of keys involved... Hang the computer up with the keyboard facing down. Next step depends on how much stuff is in the keyboard. If there are a lot of chunks, you might need to use something like Resolve, 409 or some type of critus cleaner. Spray the keyboard while it is hanging upside down. Then rinse with warm water using a spray bottle. Allow to dry for at least 48 hours or longer. Do not blow out with air or use a hair dryer which can force moisture through the membrane behind the keyboard into the computer. If the cat spew was mostly just liquid just try the warm water.
Good luck. You will be surprised how much abuse a laptop will take.
2007 HR Endeavor 40'PDQ
2012 Rubicon
2012 Keystone Outback 210RS
2013 Ford F150 FX4 Ecoboost
4 Cats
3 Dogs
2 Arctic Cats
1 Bottle of Jack Daniels
Tek-Rep
Haskell,TX USA
Posted: 01/15/12 09:58pm Link  |  Print  |  Notify Moderator
Are you using rubber gloves while you type?
Admin
Channel Islands Harbor, Ca.
Administrator
Posted: 01/15/12 11:49pm Link  |  Print  |  Notify Moderator
Technology Corner
Good luck and let us know how it turns out
Admin
RV.net
BobsYourUncle
Surrey, BC Canada
Posted: 01/15/12 10:25pm Link  |  Print  |  Notify Moderator
Just put it in the dishwasher.........
Duramax / Allison
Fire Red
1997 Triple E Topaz 27' Bunkhouse TT
81 Citation 25' "Tail dragger" "Under construction"
"Workin' man's rig"
Bob's Trucks
Check Out My Rebuild Project
Project Feedback
portscanner
Georgia
Posted: 01/16/12 04:31am Link  |  Print  |  Notify Moderator
You need one of these or most any keyboard made by Seal Shield. All of them are dishwasher safe.
One beautiful wife, two brittney spaniels
2011 Dodge 3500 4x4 DRW Crew Cab 6.7 Cummins, 6 speed auto, 3.73 rear end
Torklift Stableloads, Superhitch, Torklift Tiedowns
2002 Alpenlite 1150
2005 Jeep Liberty toad w/ ReadyBrake/ReadyBrute
Web Site
FuzzyBob
SE Michigan
Posted: 01/16/12 06:16am Link  |  Print  |  Notify Moderator
Is it a normal USB keyboard for a desktop computer? If so, just go buy a new one... Psychologically I'd always be thinking of cat yack when I was typing no matter how much I cleaned it.
laptop keyboard? get it replaced and inspect the rest of the internals, consider having it cleaned by a repair service also. Normal water will lead to corrosion over time so I can only imagine what yack would do.
2008 Suburban LT/Z71 4X4
2012 Rockwood 2304 Trailer
1 Big Fuzzy Geek (me)
1 Awesome Cookie Baker (DW)
2 Goofy Dogs
Nights camped in 2011 - 17 (not enough!)
