Open Roads Forum
Print  |  Close
Topic: Wheel Spacers
Posted By: Chief 2 on 01/16/12 05:09am
The rear tire spacing on my 2005 Chevy 3500 dually is just not enough when I have the tc loaded. There are may times when the rear tires are rubbing and I certainly am not comfortable with that. Is there anyone using wheel spacers and can you comment on how they have helped, where you purchased and anything else that may be helpful. Thanks!
2005 Lance 1181 Loaded
2005 Chevy 3500 4X4 Duramax, Edge Attitude Tuner, 5" Exhaust, Airaid, Ranchos, Air Bags, Hellwig Big Wig
2007 38RL3 Mobile Suite
2001 Bass Tracker 185
Posted By: abc40kids on 01/16/12 05:22am
Yes, there are wheel spacers www.customduallytruckaccessories.com What size tires are you running? I too have the same truck with oversized tires with no rubbing( no tc though)
Jeff,Julie,Amber,Brandon,and Casey and Winston ( our new Golden ) and Bruno the Pug
2015 Keystone Montana Mountaineer 356TBF
2005 Chevy duramax dually 4x4 crew cab,ATX wheels with Nitto Dura Grapplers and Banks exhaust.
Posted By: Chief 2 on 01/16/12 05:32am
Stock sized 16's. Thanks for the link.
Posted By: boogie_4wheel on 01/16/12 05:46am
Are your tires fully inflated? I can't believe that stock sized tires would touch each other when loaded (or even being a little overloaded).
2005 2500 Cummins/48RE/3.73, QCLB, 4wd, BigHorn, Edge Juice w/ CTS + Turbo Timer,Transgo Shift Kit ISSPro Oil and LP pressure gauges, GDP 20/2 filters, Custom Diesel Steering Box Brace
'10 Forest River Shockwave Toy Hauler 21'
Honda EU3000I Genny
Posted By: ticki2 on 01/16/12 06:14am
These are probably the best spacers out there , don't go cheap .click
GM duallys have the least space between wheels compared to Ford and Dodge . I think I am going this route also . I had a set of 2" spacers on my old suburban for over a 100k with no trouble and they were not hub centric .
'68 Avion C-11
'02 GMC DRW D/A flatbed
Posted By: Chief 2 on 01/16/12 05:48am
Running 80 psi. Even unloaded the tires sit close. My buddys Dodge has a bunch of room between his tires even loaded with the same model tc.
Posted By: ticki2 on 01/16/12 02:37pm
Chief , are you sure you don't have 235's and not 215's ?
GM spec is for max tire width of 9.1 on stock rims
Michelin 215/85/16 is 8.5 stock size
235/85/16 is 9.3
225/70/16 is 8.8
There is slight variance in brands.
I am running 235's and they barely touch at full load .
Posted By: Chief 2 on 01/16/12 03:22pm
Just double checked. 215/85 R 16 load range E. That is what is on the door and on the truck.
Posted By: Chief 2 on 01/16/12 11:44am
Michelin load range E. The Goodyears that were on there before did the same thing.
Posted By: insp1505 on 01/16/12 01:04pm
I suppose the upside is that it makes it harder to pick up a rock between the duals. I can put my fist between my tires but that also means the potential of anything else about that size lodging there when I get off the pavement. I am always checking before I get back on the pavement so I don't throw a rock at my truck or camper at high speed. So lucky you not having that concern [emoticon] but it is odd that GM would make it that close so it touches when it gets a load it. [emoticon] Good luck, hope you find what you need.
Posted By: mkirsch on 01/16/12 08:46am
Chief 2, just for kicks, what exact size tires do you have?
A 2005 should have 215-85R16.
Posted By: Chief 2 on 01/16/12 08:56am
That is the size!
Posted By: dbrojr on 01/16/12 09:56am
whats the load range and brand?
2002 f-150/jayco pop
Posted By: Chief 2 on 01/16/12 06:19am
I actually spoke with Fred yesterday. The old guy called me from Ca on a Sunday morning. He has a good product, but $320 for the pair. You get what you pay for though!
Posted By: SoCalDesertRider on 01/17/12 07:01pm
mkirsch wrote:
SoCalDesertRider wrote:
The specs on the stock wheels for a 2005 GM3500DRW pickup show 17x6.5 with a 5.00" offset. That is a very common offset measurement for dual wheels made for 215 tires. However, dual wheels made for 215 tires are usually 6" wide instead of 6.5" wide. Possibly the extra 1/2" of rim width is the problem, allowing the tires to widen out to a larger section size, more than a 6" wide rim would allow.
If anything, the wider rims would pull the tires further apart.
It's the opposite. The wider rims will allow the tires to be wider overall. Wider tires spaced the same distance apart center to center as a narrower tire, the wider tires will be closer together.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
Posted By: SoCalDesertRider on 01/17/12 07:04pm
To the best of my knowledge
The 17x6.5 wheels didn't come out until the NBS ( 2007 )
From 00 to 07 it was 16 x 6.5
Prior to 00 it was 16 x 6.0
Ford has an option for a 5.35 offset wheel 6 x 16 , to fit 235/85/16 tires
Good point on the diameter. If the width is the same 6.5" either way, 16" or 17", the result would be the same, provided the offset of both wheels are 5.00". I'd have to check on the offset for the 16" wheels.
Yes, F350 cab/chassis dually has the 5.35" offset wheels. It's stock tire size is 235, versus the 215 stock tire size for the F350 dually pickups of the same era.
Posted By: dokkema1 on 01/17/12 07:27pm
Fred Goeske........google this guy ..he makes the best wheel spacers out there...Ive run 2 inchers on my last duelly..with a truck camper..Lance 1181...it was HEAVY...no problems with spacers
Posted By: mkirsch on 01/17/12 10:37am
Posted By: ticki2 on 01/17/12 06:15am
* This post was edited 01/17/12 06:22am by ticki2 *
Posted By: BudWizer on 01/16/12 08:39pm
Chief 2 wrote:
Those are the tires I have also. Did the additional 3/8 take care of the problem? I will look into the spacers on Ebay. Thanks!
3/8 gives me just enough separation. I didn't want to go more than that because I didn't want to have to change my lug bolts to longer ones.
1995 Winnebago Vectra
2003 Suzuki Grand Vitara toad
Posted By: SoCalDesertRider on 01/16/12 10:05pm
Posted By: Chief 2 on 01/16/12 06:07pm
Posted By: ticki2 on 01/16/12 06:37pm
JoeChiOhki wrote:
Are the rims stock? Awful odd that the stock tires would rub that much, especially with something as narrow as a 215, especially with the sizes on the tires being confirmed as 215/85s.
I have to agree , never heard of or seen stock tires with stock rims touching , and I have checked many before I up-sized tires.
If the 3/8 spacers are not hub centric you may have a had time centering the outer wheel , the studs do not align it .
Posted By: BudWizer on 01/16/12 05:40pm
I had the same problem with my 06 Chevy when I put new Michelins on it. They were 215-85 16E Michelin LTX M/S 2. They just seemed too close for comfort when the camper was on the truck so I bought some 3/8" spacers on ebay. They were not expensive and only being 3/8" wide, they did not require longer studs for the lug nuts.
Posted By: JoeChiOhki on 01/16/12 03:59pm
My Blog - The Journey of the Redneck Express
CB Channel 17 Redneck Express
'2006 Heartland BigHorn 3400RL
Print  |  Close
