RV.Net Open Roads Forum: Fifth-Wheels: Portable A/C and Dehumidifier in 5th Wheel?
 > Portable A/C and Dehumidifier in 5th Wheel?
cruz-in
Southern Maryland
Posted: 01/16/12 04:38pm Link  |  Print  |  Notify Moderator
Hi,
So has anyone had experience using a portable A/C and dehumidifier in a 5er? Seems like it could solve two problems. One add a little umph to the A/C in the summer when needed and serve as a dehumidifier in the winter (or shoulder season) camping).
Any thoughts?
jimw606
Morehead, Ky.
Posted: 01/16/12 05:13pm Link  |  Print  |  Notify Moderator
If I were doing it, I would install a 110V outlet in the trailer and run a short pigtail with 3 prong plug to the outside. Then get a heavy extension cord and plug into the 110 20 amp plug on the campground supply.
Leaves the wife more amps for the Kitchen and regular A/C
cruz-in
Southern Maryland
Posted: 01/16/12 06:10pm Link  |  Print  |  Notify Moderator
Yeah it just seems like it might be the way to go. A small one could store under the bed and be removed when needed to dehumidify or assist in the cooling....
* This post was edited 01/16/12 06:47pm by cruz-in *
johnvb
Virginia Beach /Virginia/USA
Posted: 01/16/12 07:42pm Link  |  Print  |  Notify Moderator
So Cruz, did you decide not to do the second A/C on your OR?
cruz-in
Southern Maryland
Posted: 01/16/12 07:44pm Link  |  Print  |  Notify Moderator
still debating my options....the use of a portable A/C intrigued me....lots of nice units for less than $300.....plus DW does not want to give up the "skylight" in the BR so considering all options.
ScottG
Bothell Wa.
Posted: 01/16/12 09:24pm Link  |  Print  |  Notify Moderator
Don't bother with the standalone dehumidifier. It won't do anything but warm up your rig in the heat.
Scott, Grace and Wesly
H0NDA eu2000i
Splashers3
Oakville, MD
Posted: 01/17/12 03:21am Link  |  Print  |  Notify Moderator
OH contrair ScottG....you will not believe all the water our dehumidifier removes when we camp in cold weather....and since we don't have dual thermo windows, it eliminates just about all the condensation on the windows......
worth it - just be sure to get one as quiet as possible.
2008 GMC Sierra C/C 2500HD D/A - w/Titan 52Gal tank
Ride Rite Airbags, Trail Air Pin Box, Garmin Nuvi 1450LMT,
Blue Ox Bed Saver, TST Tire Monitor, Yamaha EF2000is,
2009 Cedar Creek Silverback, GII, 32 WRL w/ XPS RIBS
cruz-in
Southern Maryland
Posted: 01/17/12 04:59am Link  |  Print  |  Notify Moderator
Hummm reading the literature on them, they say they will actually cool the rig a bit (although not my purpose as i would use it in the winter). I suspect in the dehumidizer mode, it runs the A/C coils a bit to take the water out of the air.
Does your dehumidifier need vented to the outside?
mdtandem
Appleton
Posted: 01/17/12 06:42am Link  |  Print  |  Notify Moderator
I never used my A/C and dehumidifier in cold weather, but it work great as a supplemental A/C. I spent 4 weeks last summer in South Texas and Las Vegas. Daily temps were 95 to 107 with my outside thermometer showing 113 in Las Vegas. My Laredo 265RL's 13500 A/C would not keep up, especially in Vegas (Had covered windows with foil reflective bubble wrap, covered roof vents, but shower skylight was a problem)
The stand alone A/C unit enabled me to keep inside temps in low 80's using extra fan for air movement. I also had wired my unit with extra breaker box to use the 20 amp. on the outside pedestal (my laredo is only 30 amp., so couldn't have use both A/C's otherwise) You also need to vent the stand alone A/C, which I was able to do out one of my slide windows.
fishingbob61
cookevill tn
Posted: 01/17/12 07:35am Link  |  Print  |  Notify Moderator
Many years ago I used a small 110 A/C unit in a trailer with the roof mounted one and it worked great. I just put it in a window and made a frame out of plywood, and stored under bed.
Bob and Sue
40 years camping 48 years July 2011
2005 Holiday Rambler Presidential 36RLT 5th wheel
2004 Chevy 3500 D/A crew cab long bed 4x4 Dually 3.73
Honda eu3000 gen
