RV.Net Open Roads Forum: Class A Motorhomes: 8.0 QD glow plug troubleshooting
 > 8.0 QD glow plug troubleshooting
JackMS
Gulfport
Posted: 01/19/12 04:36pm Link  |  Print  |  Notify Moderator
Got the genset out today and it looks like the temp sensor is bad. It was about 60 degrees and it measured 50 ohms. Already have a new one ordered along with a belt and thermostat. Also ordered the guage panel- a bit pricey but will definitely help with troubleshooting in the future. Will also check the glow plugs while it's out. Any other suggestions of things to do while I am there?
2005 Holiday Rambler Neptune 34pdd, Cummins ISB 300, Allison 2500MH, Onan 8.0QD
Toad-2001 Chevy 2500 CC 4WD
Toad-2012 Honda CRV, Blue Ox Aventa II
catallison777
West Columbia, South Carolina
Posted: 01/19/12 04:55pm Link  |  Print  |  Notify Moderator
I figured that is what it was. And there is not much else to do, what you stated are the main things! Hope all goes well when servicing!
2003 Damon Ultrasport 3873
Onan Quietdiesel 7500
Caterpillar 3126E
Allison Transmission 3000
Honda EU2000i
1992 Jeep Wrangler(Towed 4 Down)
catallison777
Posted: 01/20/12 06:41pm Link  |  Print  |  Notify Moderator
Thanks for keeping me updated!
These sensors are pretty bad. Is your genset on a slide out? I sure do wish mine was as i would not have had to fork out all that cash for labor to get a cheap part changed, I would have just done it myself!
catallison777
Posted: 01/20/12 07:07pm Link  |  Print  |  Notify Moderator
I wish I had access to a fork lift. heck I could probably buy one if i didn't have to pay for that labor. LOL
JackMS
Gulfport
Posted: 01/20/12 06:35pm Link  |  Print  |  Notify Moderator
Catallison- just wanted to let you know. I pulled out my temp sensor today. Just like in the link you sent me, the sensor broke. I cut a hole similar to the way the guy in that link drilled a hole and used an easy out to get the rest out. I don't know what kind of sealant they put on it but it is crazy how tight it was.
JackMS
Gulfport
Posted: 01/20/12 06:49pm Link  |  Print  |  Notify Moderator
No slideout. I slid it out with a forklift. I did it last time by pulling it with an atv down some ramps onto a trailer. Much easier this time.
Tarantula
Saint John, IN
Posted: 01/21/12 05:32am Link  |  Print  |  Notify Moderator
Squirting a little ether at it while you're turning it on will clean it!! :-)
Our Unit: 2011 Lexus ES. Matador red. . Previously '05 Dodge/CTD & '06 Montana 3000RK.
JackMS
Gulfport
Posted: 01/20/12 07:27pm Link  |  Print  |  Notify Moderator
Don't let them scam you. It took me longer to get all the tools together than it did to get it out. Probably could do it in 20 minutes if you did it every day- took me about 30. Only 5 things to disconnect and 4 bolts holding it in.
