RV.Net Open Roads Forum: Tow Vehicles: parking garages
Search only in Tow Vehicles
 > parking garages
BillyW
North ID
Posted: 01/17/12 01:38pm Link  |  Print  |  Notify Moderator
I found out the hard way ONCE. Usually mine barely fits though the antenna hits every cross member. At home, the camper shell lightly scrapes every time I go in or out.
'97 F150 4X4
'04 Pioneer 18T6
96Brigadier
Calgary, Alberta
Posted: 01/17/12 04:24pm Link  |  Print  |  Notify Moderator
blt2ski wrote:
It is not the flat part you need to worry about, it is when you start to go down! I've had 3-4" of clearance, only to drag the rear of the ladder rack as the front dips down, the rear rises up.....
Marty
x2. Just because you can get through the entrance to a parking garage doesn't mean you can make it up or down the ramps. The angle of your truck changes the clearance. I was inside a buddy's one week old Excursion when we went into a parking garage. First level no problem, going to the second level he wedged it into the roof. We had to let air out of the tires and get extra guys to stand on the running boards before we could back it out.
My 2010 Dodge is about 6'2" high. Unless the garage says 7' clearance I won't go in, and then I am very careful going to a different level (up or down).
2010 Dodge Ram 3500 4x4 Megacab Laramie, 6.7L CTD
Truck weight 8,448 lbs with hitch, wife, two kids, full load of diesel
2010 Keystone Cougar 293SAB
Pin Weight 1,800 lb, Trailer Weight 10,300 lb
(Loaded for camping w/ full water tank)
doublenot7
Clear Lake, Texas
Posted: 01/17/12 07:17pm Link  |  Print  |  Notify Moderator
I have a 2011 F250 4x4 with 20" tires. I just stay out of parking garages unless they have over-sized parking.
Perrysburg Dodgeboy
Perrysburg, Ohio USA
Posted: 01/17/12 07:29pm Link  |  Print  |  Notify Moderator
Not sure why the parking garages in some areas don't have a gauge before you enter. I don't think there are any around here that don't have them! They are set about 6" lower then the lowest spot of the park garage. If you hit it you should not go into the garage, if you do it's on you if your vehicle is damaged or damages the garage.
Don
Perrysburg Dodgeboy
2004 Dodge Ram 2500 Quad Cab SLT Cummins HO
2005 Keystone Cougar 304 BHS
Chrysler the only one to pay back 100% of their loans from the Government. *The Old Car Company" still owes 1.6 billion. Is that better Chuckles
Jarlaxle
New England
Posted: 01/17/12 08:36pm Link  |  Print  |  Notify Moderator
Be aware: some garages are not rated for the WEIGHT of a HD diesel pickup. I have seen one rated for 6500lbs, both my F350's comfortably topped that!
John and Elizabeth (Liz), with 3 nutty cats
My beloved St. Bernard, Marm, lost him 1/2/12
Current rig:
1992 International Genesis school bus conversion
camperfamily
New Jersey
Posted: 01/17/12 09:57pm Link  |  Print  |  Notify Moderator
I park in a garage at work every day. Got used to it. Then went in a garage in Charleston, SC. Damn, that was a close fit. Antenna did some scraping, was hoping that the clearance lights we're not next. Had to back out of one, people behind us were NOT happy. Went around, had to park in the "RV" slot as we couldn't get up the ramp to the rest of the parking. Would 7' clearances really kill them building garages? How do emergency vehicles and tow truck access those structures?
2007 Pilgrim 278BHSS
2002 F350 CC LB PS
B&W Companion Hitch
wbwood
Mooresville/Troutman, NC area
Posted: 01/17/12 10:48pm Link  |  Print  |  Notify Moderator
My truck will not fit in the parking garage at work. So when I drive it, I have to park on the top, which has a different access. Other peoples trucks, including a brand new F150 with 4x4 fits fine. But my 250 4x4 stock doesnt...
Brian
RVing Illustrated
2010 Keystone Sprinter Select 31BH
2001 Coleman Santa Fe
t?m
Ohio
Posted: 01/18/12 10:34am Link  |  Print  |  Notify Moderator
Thanks for the input. I've noted some new "green" LED lights that look to be lower than the old ones in the last few months. Also a panic button and rotating light in a couple places. I guess I'll be switching to a parking lot space and have to wait on security for a ride now.
kehale
Arizona 2011
Posted: 01/18/12 11:43am Link  |  Print  |  Notify Moderator
I got stuck at the airport parking once. Entered and it said 7'2" minimum clearance.
They were doing work to the exit, so they made a temporary asphalt ramp out another opening of the concrete structure. The ramp was such that the clearance was reduced to about 6'6". (my truck is 6'8" tall)
I was stuck with about 5 to 10 cars behind me. I got out and aired down the tires to get out (took about 10 minutes)
In that time, Airport Police were on the scene and threatening to detain me (for what?).
Every single time I go to the airport, I get stopped for "secondary inspection". I'm told that it's random and that they don't profile. However, in secondary, the inspector told me, "We don't profile, but if you don't want to get inspected every time, take the tonneau cover off your truck".
HOW IS THAT NOT PROFILING?
What were we talking about again? Why is everything so red? It's hot in here....
(moral of story: My marked antennae saved my butt!)
Ok, I feel better now.
06 Lance 1181
 > parking garages
