mjn112
Nevada
I have a Forest River 18ft. travel trailer. The dry weight is 4400lbs. I am accounting for another 1000lbs. in people, supplies, bikes, etc...
I am looking at a 2008 Dodge 1500 Ram 5.7l. The truck has a tow capacity of 7700lbs.
Is this vehicle a realistic choice to tow my trailer and supplies?
Thanks!
downtheroad
Pacific Northwest
Perfect...get a good hitch set up and enjoy your new adventure..
Welcome to the Forum.
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
LAdams
Northern Illinois
I see NO problems with this combination - good luck with the new truck and welcome to the RV.Net Forums
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
Sold Trailer - not RV'ing at this point in time
HUNTER THERMOSTAT INSTALL
HOME MADE WHEEL CHOCKS
skipnchar
Topeka or somewhere else
Should be a good match. Good luck / Skip
WV_Tacoma
Huntington WV
I have a TT 08 Passport 20'(no slide) about 4000#+1000#junk=5000# and tow with 05 Toyota Tacoma (mid size) truck, tow rating is 6500#. I think its 1/2ton truck..don't know. It tows fine for 2-4 trips, avg 1000miles each way.....But with out my Hensley arrow tow thing, it makes for a long 1000miles....and frankly not a good idea.
I assume also the tow rating is for a flat trailer with that max weight.... Cause when you take max.. x big billboard box thing, it like leaving the park brakes on. So I stayed well under my max rating.
RoyB
King George, VA
I get great gas mileage pulling my 4200LB loaded POPUP trailer using 3:73 gears but of course I dont have any wind resistance. My truck listed below gets 20-21 MPG whether I am pulling my POPUP or not... You should do well with your planned setup...
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
MeandMyLabs
Clinton, Illinois
You should not have any trouble. I pull a trailer of about the same weight with my F150 5.4, sometimes with a ATV in the back and have never had an issue.
2013 XLR 27 HFS
2009 Chevrolet 2500 HD 6.0 L
Yamaha 2400is
Champion 4000 watt
Yamaha Zuma 50cc
Kawasaki Brute Force 650
Camping Buddy - Raji (yellow lab)
LVJJJ
NW WASHINGTON
WOW, finally a smart new member that is going to buy a TV to tow a TT well within it's towing capacity!
1965 CHEVY VAN, 292 "Big Block 6"
1985 WILDERNESS 3000CL
2008 HHR
L(Larry)V(Vicki)J(Jennifer)J(Jesse)J(Jason)
beemerphile1
I'm 57, I'm not a
mjn112 wrote: I have a Forest River 18ft...I am looking at a 2008 Dodge 1500 Ram...tow capacity of 7700lbs.
Thanks!
You should be fine with that combo.
But a tip for you and anyone else that may read this; Do not go by the dry weight numbers from the manufacturer. It is a mostly phony number for a fictitious trailer with no equipment. Everyone should ignore the dry weight number and only consider the GVWR. The GVWR will be on the legally mandated ID tag typically located at the outside left front.
If you can tow the GVWR, you can tow the trailer. No one tows an empty trailer.
- Soren Kierkegaard
passport2590bh
Plenty of truck for your trailer.
Expect 9-10 mpg while towing travel trailer, but that is the norm.
Does your truck have tow package / transmission cooler?
2006 5.7L Ram 1500 Hemi Mega Cab
2011 Keystone Passport 2590bh GT
