RV.Net Open Roads Forum: Towing: Husky Centerline hitch
Search only in Towing
Open Roads Forum  >  Towing
 > Husky Centerline hitch
slohand
Kinzua
Posted: 01/18/12 08:52am Link  |  Print  |  Notify Moderator
Does anyone have the Husky Centerline and are you satisfied. I have researched 3 different hitches and like the engineering of the Husky not necessarily the price. I have read good reviews on Reese's and the Equilizer but I believe you lose ground clearance with these. Tell me if I'm wrong because the husky runs about $100 more.
Thanks,Dave
downtheroad
Pacific Northwest
Posted: 01/18/12 08:58am Link  |  Print  |  Notify Moderator
We have the Reese Dual Cam Strait-Line set up..(flat trunion bars)
Lots and lots of miles coast to coast and back again in every type of terrain and conditions and never had any clearance issues.
You most likely will have clearance problems (in and out of driveways) with your trailer's rear frame rail long before your hitch will scrape.
Arctic Fox 25Y
GMC Duramax LBZ
Blue Ox SwayPro
netomh
Far North Dallas
Posted: 01/18/12 09:24am Link  |  Print  |  Notify Moderator
Thanks,Dave
Have it. Satisfied. Two things to think about.
1) Truck and camper have to be within 5 degrees of straight to install/remove the WD bars. Many folks consider that a show-stopper, but for me it's not that big a deal. It hurt like hell, though, the one time I tried to force it and took a bar to the bicep. It hit so hard, it split the skin, and the bruise was pretty spectacular. Respect the angle.
2) It's been out for several years now, and has not really taken off...meaning your local RV & parts dealers will probably not have parts on hand should you need them. (Nothing has ever broken on mine, but I lost a critical part due to sheer stupidity, and had to overnight a replacement because no one in DFW had any on hand...shipping was twice the cost of the part.)
2010 Ram 2500HD Crew ST, 6.7L, 68RFE, bone stock.
2010 Keystone Sprinter 311BHS
APT
SE Michigan
Posted: 01/18/12 09:59am Link  |  Print  |  Notify Moderator
Love my Reese DC, although it is a bit picky about being adjusted correctly. A little bit off, and it feels like you've done worse by using it than without. Never an issue with ground clearance, and I have a low (2-step) TT.
2012 VW Passat TDI
2017 Subaru Outback 3.6R
JBarca
Radnor, Ohio, USA
Posted: 01/18/12 10:45am Link  |  Print  |  Notify Moderator
Thanks,Dave
Hi Dave,
Clearance issues, It depends and there are ways around many of these isses. But we need to know more about your setup. As a generic flat out statement that you will have ground issue is maybe a preconcived notion. I have been able to help folks get either an Equal-I-zer or a certina types of Reese to fit up well even on low rider TT's. But there is not one that fits every TT ever made.
1. What is the ball coupler height from ground to inside coupler with TT level?
2. What is the reciever height on the truck from ground to top on the inside of the 2" pin box hole where the shank will go.
3. What is the width of your TT A frame? 4", 5", 6"?
4. Is your ball coupler on the top, middle or bottom of your TT A frame?
I'm assuming this is a light TT as the heavy ones are way up there, what empty and ideally loaded tongue weight range are you in?
And what brand/model TT is this? That helps too.
Pending those answers we can better help tell if the Reese and which one or the Equal-I-izer will have issues.
Pending what you have I may even have a pic of a hitch on a TT to show you.
Hope this helps
John
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we were camping!)
slohand
Kinzua
Posted: 01/18/12 12:53pm Link  |  Print  |  Notify Moderator
The TT is a denali 289 RK. I am ordering it tomorrow. I assume I will need a WD hitch to tow it home once it comes in. Maybe I am wrong. Would be about 30 mile tow. I have a '11 Chev. 2500 to tow it. Can't come up with the measurements you need off hand but maybe tomorrow I can.
Thanks, Dave
APT
SE Michigan
Posted: 01/18/12 02:03pm Link  |  Print  |  Notify Moderator
If you prefer to buy a WD hitch and install and set it up yourself, your truck will do fine without it for a one time trip home if you keep the speed down to say, under 55mph.
Fisherguy
Vancouver BC
Posted: 01/18/12 04:37pm Link  |  Print  |  Notify Moderator
I would not have a hitch where I need to be perfectly straight to do it up, we usually go to more rustic campsites, no pavement etc and with the length of our unit we're on an angle to hitch and unhitch more often than we're straight in line.
No complaints about the Reese DC.
06 Dodge Ram 3500 Cummins 6 spd std with a few goodies.
2007 Komfort 274TS, SteadyFast stabilizers, Trimetric 2025RV, PD9280, Honda EU2000i, Xantrex SW600, shocks and EZ-Flex suspension, Reese Strait-Line
480 watts of solar
Bob/Olallawa
Kitsap Co, WA
Posted: 01/18/12 05:07pm Link  |  Print  |  Notify Moderator
Not much difference in the Husky and the other top brands like Reese and the EZ-lift. I would think you would have plenty of room.
Welcome to my home, that door you just broke down was there for your protection not mine.
ReverendCharles
on the road
Posted: 01/18/12 05:35pm Link  |  Print  |  Notify Moderator
I have one and they are heavy, easy to setup and really keep the trailer from swaying. I was pulling in strong winds, no sway at all, I could feel the hitch correcting the trailer and it was very stable. As far as unhooking when straight no problem just drop the bars before you wedge the trailer into a tight site, this is also easier on the trailer frame no matter what wd hitch you are using. Charles
