RV.Net Open Roads Forum: Truck Campers: Changes for truck
 > Changes for truck
narcodog
Georgia
Posted: 01/18/12 08:20pm Link  |  Print  |  Notify Moderator
I have changed the air box, headers and an exhaust system. My mileage did go up but not much. Chips in gassers are a waste of $$$.
bcbigfoot
Okanagan
Posted: 01/18/12 08:33pm Link  |  Print  |  Notify Moderator
I have read and talked to few guys that the early 6.0 litre engines respond well to chips, better mpg and some will help reduce the constant downshifting issues that the 6.0 has. I don't think you want to go to 3.73 gears. The 6.0 just doesn't make much torque down low just lots of hp up top.
2002 Dodge 3500 2wd dually, cummins, 4.10 gears, 10500gvwr, Rancho 9000's shocks
2005 Bigfoot 259.6E, 80watt solar, 7100btu aircond.
SoCalDesertRider
SanDiego, CA, USA
Posted: 01/21/12 10:23am Link  |  Print  |  Notify Moderator
elkhornsun wrote:
Slowing down will do the most to improve your truck's mpg as taking only what you will need so as to keep the weight to a minimum. When you replace your tires there are ones with a much lower rolling resistance and they may not have as aggressive a tread but they will help maximize mpg if kept at the correct pressure.
To minimize what I spend on gas and diesel I use www.gasbuddy.com to find the cheapest prices both locally and when planning a trip. I save $0.20 to $0.50 cents per gallon by finding the cheapest places to fill up the tank.
That is very true. Good post.
Good advice on the Gas Buddy web site too.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
elkhornsun
Monterey
Posted: 01/21/12 01:57am Link  |  Print  |  Notify Moderator
Terrick down Under
Australia
Posted: 01/19/12 05:18am Link  |  Print  |  Notify Moderator
Might I make a suggestion.
Down here my 93 Chevy 7.4 runs on gas and LPG(propane). The gas sells for $1.46 per liter ($5.52/gal) and the LPG sells for $0.65/liter. When on LPG it runs about 25% cheaper in $/mile. It is computorised and altitude sensative to give optimum performance. I do approx. 800 to 400 m/week now, as the dually is used for servicing on rural properties. The system paid for itself in the first two years as I was doing over 1200 m/week. I lost about 250 lbs payload due to the tanks. If you have a good dyno mechanic around you, ask him to spare you half an hour to talk thru it. The spare tyre sits in the back during the week with my tools, and I am making a front mount for carrying it when the TC is on.
See how you go, it might work as well for you, as it has for me.
Terrick
mgann
Fayetteville, NC
Posted: 01/19/12 04:22am Link  |  Print  |  Notify Moderator
Thanks to you all for the great advice, and I will take it. I'll drive her like she is and save my $$$$ for gas.
Max Gann, Fayetteville, NC
02 GMC 2500HD, crew cab, srw, 2wd, 6.0 gas, Airlift bags, Rancho 9000"s, Reese Titan V, 2006 Northstar 650 with nice options.
SoCalDesertRider
SanDiego, CA, USA
That is a good plan.
 > Changes for truck
