RV.Net Open Roads Forum: Class A Motorhomes: Mounting a telescope TV Bracket
 > Mounting a telescope TV Bracket
Mr. Shneebly 714
Anaheim,CA
Posted: 01/19/12 09:01pm Link  |  Print  |  Notify Moderator
I would like to modify where my TV is located and need to install a TV mount on an inside wall near the bunks. How would I know if it's safe to run screws through that particular area?
2012 Bounder Classic 34B
katoomer
Vancouver
Posted: 01/19/12 10:03pm Link  |  Print  |  Notify Moderator
If it is an inside wall you shouldn't have a problem. What is on the back side of the wall?
If it's the shower it could have water lines in it. Check the wall thickness the best you can, you don't want a screw coming out the other side.
Safest bet is to drill a tiny hole ( say 1/16 ) before you install a screw to see if you hit something. If you can't mount a screw there you can just fill the tiny hole with a putty stick to match your wall color. If you can't hit any solid backing use butterfly syle toggle bolts for mounting the bracket. They will hold lots of weight for their size. 1/8 or 3/16 are more than adequate for todays TV's.
2009 Newmar Ventana 3942
2010 Pace Shadow 18ft
2010 KTM 450 XCW six days
2010 Can Am Outlander 650 XT
2009 Yamaha TTR125
1989 Douglas Skater 21' Twin 2.5s
CloudDriver
New Jersey Shore
Posted: 01/19/12 10:31pm Link  |  Print  |  Notify Moderator
If your Bounder is similar in construction to our Minnie, I think you are going to find that the inside walls are hollow with a skin of thin plywood on both sides. Structural strength is obtained by a solid wood frame around the perimeter of the wall and a stud or two depending on the wall length. If you try to attach a TV to just the thin plywood with anchors, I think you are going to find the TV on the floor after driving over a few bumps.
IMO the best thing to do is to call Fleetwood and ask them where in the wall there is some solid structure to attach the TV mount to.
2003 Winnebago Minnie 24F - Ford E-450
