RV.Net Open Roads Forum: Tech Issues: Water Heater Propane Valve Leaks
 > Water Heater Propane Valve Leaks
Delman
Ocean View, Delaware
Posted: 01/20/12 09:45am Link  |  Print  |  Notify Moderator
The gas valve on my Atwood electronic ignition water heater is leaking a very small amount of LP.....is there anything short of replacing the valve that can be done to correct the leak.
Thanks in advance for any advice.....this forum has been a great help to me in the past.
pulsar
Lewisville, NC
Posted: 01/20/12 10:34am Link  |  Print  |  Notify Moderator
Moved from Forum Technical Support to Tech Issues.
OldF**t
Crossville, TN
Posted: 01/20/12 10:54am Link  |  Print  |  Notify Moderator
Had the same problem. Propane was seeping out of a small weep hole on the back underside of the valve. The only real option is to replace it. Relatively inexpensive.
Jim
2004 Hurricane 32R (F53)
Demco Excalibar
2010 Ford Ranger 4X4
2009 Kymco Xciting 500Ri
1 wife and 7 cats
Delman
Posted: 01/20/12 11:55am Link  |  Print  |  Notify Moderator
I soaped the valve and the only propane leak is from the orifice.....I'm guessing the valve is sticking from lack of use.
2009 McKenzie Medallion Estate
2007 Chevy 2500HD Duramax
Once upon a time I was a little kid.....now I just think like a little kid!
dougrainer
Carrolton, Texas
Posted: 01/20/12 02:47pm Link  |  Print  |  Notify Moderator
LP valves are not servicable. Replace only. Seeping thru the orifice on an OLDER Atwood water heater is a common problem. Doug
