RV.Net Open Roads Forum: Technology Corner: accurate satellite pointing without a compass
 > accurate satellite pointing without a compass
Stranger
Sparks, NV. USA
Posted: 07/10/12 12:01am Link  |  Quote  |  Print  |  Notify Moderator
TechWriter wrote:
Stranger wrote:
I just use the signal strength meter that is built in to my Dish Network receiver.
This gets a bit tedious when your dish is 150' away.
Does the cell phone work 150 feet? Just sayin'. We use the radios we use for backing. Probably don't need radios with a MH, tho.
Life is not a journey to the grave with the intention of arriving
safely in one pretty and well preserved piece, but to skid in broadside, thoroughly used up, worn out and defiantly shouting "Wow, what a ride!".
2002 3500 6 Speed
2005 ALFA
Just 72 feet!
TechWriter
On The Road
Posted: 07/10/12 04:52am Link  |  Quote  |  Print  |  Notify Moderator
Been there, done that. Get a good tripod & meter.
2001 Newmar Mountain Aire 4095 DP
Full Timer since May 2013
- Solar -- Solar Power
- Water -- Water Filtration
- Blog -- www.rvSeniorMoments.com
bob213
Fresno, CA
Posted: 07/10/12 11:05am Link  |  Quote  |  Print  |  Notify Moderator
Does anyone have any suggestions on what to use to weigh down the tripod if you are in one of those parking lot type campgrounds and you can't put a hole in the asphalt?
schneid
In the Wind
Posted: 07/10/12 11:38am Link  |  Quote  |  Print  |  Notify Moderator
TV4RV.com HD Tripod kits come with a metal gizmo that keeps the kegs from spreading where you can't get them in the ground. The bottom of the mast has an eyelet. I tie mine to a 5 gal bucket and fill it with water or rocks depending on the length of stay.
Leg Restraint Kit
* This post was edited 07/10/12 11:45am by schneid *
bob213
Fresno, CA
Posted: 07/10/12 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks schneid. That looks like it will do it. I got laughed at when I posted that I use 5 gal. buckets as hold downs for my ez up or awning. Glad to see some one else is as unrefined and resourceful as myself.
