RV.Net Open Roads Forum: General RVing Issues: Rigid Foam Insulation
 > Rigid Foam Insulation
1L243
Astoria, Oregon
Posted: 01/23/12 12:23am Link  |  Print  |  Notify Moderator
I was wondering if anyone has used Rigid Foam Insulation to insulate the underbelly of your TT? I have read that it's waterproof and can be cut and mounted easily with special fasteners?
2011 Work and Play 30WR. Added 2nd AC, four deep cycle batteries.
camperpaul
Wherever I park my travel trailer
Posted: 01/23/12 05:01am Link  |  Print  |  Notify Moderator
I hqave used the pink foam insulation and it did make a small difference.
Putting a skirt around the bottom made a lot of difference.
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
1982 6.2L Diesel Suburban 1500
garry owen
riverton wy
Posted: 01/23/12 02:09pm Link  |  Print  |  Notify Moderator
skipnchar wrote:
Use Coroplast as nearly all manufacturers do and place the insulation inside the coroplast belly liner. Just the insulation will not hold up well when exposed to sand, gravel and high speed winds from the highway.
Good luck / Skip
its good to know the name of this stuff.
have been looking for this to seal the bottom of our T H.
have been looking for source and find many for signs ect but not for rolls or something that would be suitable for belly liner
would appreciate a source or name to google that would get me closer to the belly liner material.
thanks, gary
2010 HD Silverado club cab Dura Max FS3000 Weekend Warrior
X2 550 Sportsman 500 Sportsman
cm
Dillon, CO USA
Posted: 01/23/12 05:50am Link  |  Print  |  Notify Moderator
There are several types of rigid foam insulation so it is best to research the different types.
Expanded polystyrene, bead board, is what most RV manufacturers use in walls, ceilings, etc. It has the lowest R-Value, R-4 per inch. While the material itself doesn't absorb moisture the bead like structure can "hold" some moisture. The beads can flake off when handled or used over time. This is the white pellets that some people complain about coming out of their air conditioning ducts. It is less expensive.
Polyisocanurate, polyiso, has the highest R-Value, R-6.5 per inch. It comes with a foil facing. But it also is more fragile, meaning it is not as strong and can be not as durable. It is the most expensive.
Extruded polystyrene is possibly the best choice. R-5 per inch and is more durable so it is easier to handle. It is available in thicknesses of 1/2 inch, 1 inch, 2 inches, and more. The standard version that you will find at the common building material dealers is 25 psi. High load versions are available, 40 and 60 psi, but you will have to get them from a commercial insulation distributor.
And as far as a pink color all that means is that the manufacturer is Owens Corning. Pink is their marketing color. I have seen extruded polystyrene in pink, blue (Dow Chemical Co.), green, black and even white. The pink color is the Owens Corning Formular brand. Dow Chemical uses the blue color. It is their Styrofoam Brand. And this is the only real Styrofoam. Styrofoam is a brand not a generic term.
You can layer extruded polystyrene. So it you want to use 2 inches you could install two one inch sheets if installing the one inch sheet is easier. You can glue it together, or to the floor, provided you use a glue that is designed for polystyrene materials. Due to the vibration found in a RV and the fact that it will be installed flat, some mechanical fastener or support would be a good idea.
ExRocketScientist
Laurel, MD
Posted: 01/23/12 06:18am Link  |  Print  |  Notify Moderator
I used extruded polystyrene when I enclosed the fresh water and black water tanks and heated them. I covered the stuff in fiberglass cloth using polyester resin. I sealed any gaps with great stuff. I also built a subfloor heated/insulated compartment with the same materials for the batteries (AGM laying on their sides).
The best way to cut the stuff is with a table saw or circular saw with a really sharp carbide blade.
ERS
skipnchar
Topeka or somewhere else
Posted: 01/23/12 07:45am Link  |  Print  |  Notify Moderator
Good luck / Skip
Wills250psd
walnutcove NC
Posted: 01/23/12 02:22pm Link  |  Print  |  Notify Moderator
garry owen wrote:
Good luck / Skip
thanks, gary
x2 I would like to know where to get it that wont break the bank? thanks will
BillyW
North ID
Posted: 01/23/12 02:34pm Link  |  Print  |  Notify Moderator
I used rigid styrofoam on my holding tanks, filled the gaps with expanding foam (great stuff), then ran coroplast between the frame rails to protect my handiwork.
I was able to buy the coroplast locally for about $12/sheet I think. It's been some years now.
'97 F150 4X4
'04 Pioneer 18T6
ExRocketScientist
Laurel, MD
Posted: 01/23/12 04:29pm Link  |  Print  |  Notify Moderator
Wills250psd wrote:
garry owen wrote:
Good luck / Skip
thanks, gary
Go to a sign shop. They usually have stacks of the stuff. It wouldn't be the first time someone came in a bought a piece off of them for something other than a sign.
LarryJM
NoVa
Posted: 01/23/12 02:46pm Link  |  Print  |  Notify Moderator
When I sectionalized my coroplast underbelly I put in some of the Dow Corning Formular 250 1" insulation in about 72% of the underbelly area as shown in the following picture:
I simply slid it on top of the underbelly and the supports I made and here is a pic of one section:
Not sure how much difference it made, but it was a cheap addition and I figured every little bit of extra insulation in that area could only help.
Larry
